Old 11-24-2003, 10:27 PM
sweenrace sweenrace is offline
changing spark plugs?
Hi all,
i have a 2001 silverado 6L HD. i want to change the plugs but there a metal shroud around the plugs. does this just pull off the plug like standard lead?
also, any recommendations for plugs and leads?
by the way, the motor pings!
thanks
Old 11-27-2003, 10:22 PM
tooltimetech tooltimetech is offline
Yes it pulls right off with the spark plug wire. Only recommend factory replacement parts (GM). While you could shop around and find the parts cheaper initially, it will cost more in the long run. No I don't sell parts, this is my honest belief.
Old 12-01-2003, 01:10 PM
Re: changing spark plugs?
thanks tooltime.
i pulled the wires and the plugs and didnt see any surprises. i'm going to change them anyway. the ower manual doesnt list the spark plug type to use. any suggestions? there are ac delco/NGK plugs in it at present but i have no way of knowing if they are the correct ones
thanks
Old 05-15-2004, 08:06 PM
davideo davideo is offline
Plugs are listed in the Manual
Old 08-08-2004, 01:17 AM
stubbornmike stubbornmike is offline
I used acdelco rapid fire double platinum..
single platinum melted the first time they were installed so went with double.
