Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 11-24-2003, 09:42 PM
Bryants95240sx's Avatar
Bryants95240sx Bryants95240sx is offline
Send a message via AIM to Bryants95240sx
worth it ?
http://w1.igateway.com/clients1/tc/s...ifunction=form
See ya....
Old 11-24-2003, 09:53 PM
Suislide's Avatar
Suislide Suislide is offline
you can piece together a custom kit for way less.
on the other hand, you can be guaranteed with this one...whereas one pieced together might have it's share of problems..
2 sides to this card. you pick which to follow!
-Brian
2013 Subaru BRZ Sport-Tech 6MT. Not stock.
Old 11-24-2003, 10:13 PM
stealthj's Avatar
stealthj stealthj is offline
Send a message via AIM to stealthj
Re: worth it ?
I also believe that this Greddy Kit is CARB legal? or pending I should say, so IF you are in California, go ahead with this, other wise way cheaper to build yourself.... or just steal a carb sticker from something :-)
BANNED
Old 11-25-2003, 09:36 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
- Manifold (poor design. runners connected at end. no spacing cut into the plate connecting the runners for expansion. bolt holes all the same size. have fun with that one guys....)
- Internal Wastegate (seriously, why would anybody use an internal wastegate anymore)
- Lack of I/C (don't plan on raising the boost above the 6 psi it's set to run at)
- 370cc injectors (wtf? almost no room for raising the boost)
- Designed only for OBDII (Greddy didn't even get the years right in their description. OBDII started in 96 on the 240's, not 95. They are basicly saying, "don't plan on running this setup on your S13 unless if you spend more of your money on extra parts."
- Overall
If you want to buy a kit already put together, spend a little more and go with nsport, fmax, or xs.
Old 11-25-2003, 10:12 PM
mynismo mynismo is offline
yada yada yada
Send a message via AIM to mynismo
Re: worth it ?
no fmic for almost $3000... that's a lot.
i heard www.realnissans.com makes some good stuff
438whp / 373tq - 11.9 @ 126
Old 11-26-2003, 01:05 AM
mrflip69 mrflip69 is offline
Re: worth it ?
Are they advertising the kit to be used on S13s?
Old 11-26-2003, 01:24 AM
nightwalker nightwalker is offline
Send a message via AIM to nightwalker
I say, SCREW GREDDY!!! Most horrible customer service in the world! Right next to JIC. Try calling them up. I seriously think they pay some guy 8 dollars an hour to pick up a million calls and tell them to go back to the shop they bought it from. They don't even try. HKS on the other hand is bomb. Yeah, some Greddy products suck balls too, not just the turblow kit. Its just a name. Buy something else out there that is made better.
“Before buying the next go-fast part, invest in the most tunable component yet... the driver's mind”
Old 11-26-2003, 10:31 AM
Re: Re: worth it ?
no, but they are advertising it to go on the S14, and it still doesn't even go on all S14's. It will not work on the 95's because of the OBD1.
Old 01-04-2004, 01:25 AM
blake240 blake240 is offline
Send a message via AIM to blake240
i say get the sr swap get a boost controller an run about 13lbs or boost in it u'll have around 240-250rwhp
http://www.srswap.com/html/products/s13redtop.htm
