Old 11-24-2003, 09:33 PM
NismoCar NismoCar is offline
cost for a B18c swap into EG civic
1.How much would it cost to get everything I need for a B18c swap into a 92' civic: engine-trans-axles-ECU-harness-anything else I missed.
2.Wheres the best place to order this stuff.
3.My friend said that its easer to use a USDM B18c than the JDM because of the ECU and the wiring harness, so should just go with that or go JDM.
Old 11-25-2003, 12:28 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: cost for a B18c swap into EG civic
1. $3200 + shipping
2. http://www.hmotorsonline.com/shop/sc...age&item=30009
3. JDM wiring harness's are for RHD cars, so everything plugs into the otherside of the enginebay. You can use the JDM harness to use the plugs, and just use your stock civic harness on the motor. JDM ECU's are speed governed, but they work just fine, you can however get a P28 from a 92-95 Si/EX, and have it chipped to run the 1.8 DOHC better than a stock one.
Old 11-26-2003, 05:19 PM
salbaje salbaje is offline
Send a message via AIM to salbaje
b18c in eg
motor will run 3000-3500 depending on where you order it. install usually runs 350-700. Hit me up i can get everything for you. i'm in Northern cali
Old 12-01-2003, 11:27 AM
18c5sol94 18c5sol94 is offline
Re: b18c in eg
you should hit him up he doing my swap for me you can trust him no bull shit either he tell you what you need
Old 12-01-2003, 01:27 PM
totalboost totalboost is offline
Send a message via AIM to totalboost
B18C EG!!
Total-Boost.com
JDM ENGINES
TOLL-FREE: 1-88-TOTAL-JDM (1-888-682-5536)
AIM: totalJDM
Know someone who needs a JDM motor? Earn $$
