| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
wiggley shifter
my shifter has been really wiggley and it almost seems like it is in nuetral when it really is in gear. how can i fix this and what is it caused by? thanks
Re: wiggley shifter
you could check your bushings for you shifter, and stabalizer bars.....Friend had same problem..
94' Del Sol VTEC (B16A3) SOLD. Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles. |
Re: Re: wiggley shifter
anyone else got any ideas or is this exactly what it is. and where can i get new bushings and where do they go? i don't remember seeing any bushings around my short shifter when i installed it. thanks
Re: wiggley shifter
if you didn't see any bushings then you have problems. They go in the center of the bottom of the shifter (the part that looks like an eye), around the bearing that you put the bolt through to hook upthe shift linkage.
Re: wiggley shifter
The mounts go on the stabalizer rod - 1 at the bottom of shifter & the other located on the trans end - very simple to install - cheap - a must with short shifter
www.summitsportcompact.com - energy suspension $10.69 www.jcwsportcompact.com - prothane $9.95 |
ok well i didn't know those were the bushings and i do have those so all i need is energy suspension and prothane? thanks fo the help
Re: Re: Re: wiggley shifter
which are better the prothane or the energy suspension? thanks
Re: wiggley shifter
The bushings wear over time resulting in a sloppy shifter feel, with the poly bushings your shifter will be very tight. If you want it tighter(i dont recommend) you could use B&M solid aluminum mounts. I personally like ES over Prothane, its all the same shit.
