Old 11-24-2003, 10:45 AM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
Oil Temp Sensor Location
Is there any where i can put my oil temp sensor where i could just screw it in instead of welding a bushing in my oil pan? thanks.
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
Old 11-24-2003, 03:03 PM
kjewer1 kjewer1 is offline
AF - Advisor
You have a few options, but first let me show how the oil system is setup. The oil filter block, or housing, or adapater, or whatever the hell you want to call it, is bolted to the front of the motor, partially behind the tbelt cover. The filter does a 180 off it, towards the down pipe. There are 2 sensors already there. The rearward one is the factory guage sender. The forward one is the idiot light sender. You could replace either one of those, probably the light since by the time it comes on you are at zero psi anyway... But thats your call. I kind of like having the light around anyway just in case. Either hole can be tapped for 1/8NPT fitting. The japanese version just has one more thread, if they use BSP standard as I suspect, which is 1/8th-28, while in america we use 1/8th-27. Anyway, it can be tapped. If you have never tapped for tapered pipe threads, let me know and I can write up a quick faq.
There are also 2 taps on the front side (front bumper side) of the filter housing, either above or below the idiot light sender, I forget which. One will already be your turbo oil feed tap. Both fittings are I BELIEVE close enough to use 3/8th NPT fitting. Supposedly thats what all the turb companys use for our SS oil line kits, and 3/8th to 4-AN elbow. If thats the case you'll just need an adapter to drop the 3/8th NTP down to a female 18/th NPT, which is what I'm assuming your oil temp guage sender is. It may be 1/4NPT as well. Just get the appropriate adapter. The 3/8th tap that you would be using is taking the temp before the filter. The one for the turbo feed is obviously after the filter.
If you want the temp of the oil after it has passed through the motor instead of from the oil pan/pickup, you can tap into the passenger side, front corner of the head, where the 1g gets its turbo oil feed from. Unfortunately I dont know off hand what size those threads are, but I know poeple have put 1/8th NPT pressure sensors there.
Good luck
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-27-2003, 06:01 PM
95_GSX's Avatar
thanks for all the info. that sounds like something i will take a look at on Saturday when i am building my exhaust. i will already have all my tools out then. thanks.
Got AWD?
'08 Buell 1125R
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
