Old 11-24-2003, 02:41 AM
Dakotarota Dakotarota is offline
How to replace fuel filter?
How do I (any special tips) & where is it?
Thanks
Old 11-24-2003, 07:43 AM
LastOne LastOne is offline
On many of the fuel injected models it is on the inside frame rail about where the drivers door is. Be careful and try to relieve pressure. System is pressurized to 60+ PSI. Just do it outside and be careful. Not much to it.
Old 11-24-2003, 11:07 AM
Ok so how do I remove the fuel filter releasing the pressure carefully?
Jason
Old 11-24-2003, 11:54 PM
bim's Avatar
bim bim is offline
Send a message via Yahoo to bim
You could let the truck sit for a while and the fuel pressure will bleed off or there is a port with a schrader valve in it thats used to check the fuel pressure mounted on the fuel rails. CAREFULLY with a rag wrapped around it push in the pin on the schrader valve the same way you would let air out of a tire. But remember there will be fuel coming out of it under high pressure so I don't recommend it unless you are comfortable doing this. Good Luck.
2002 1500 Ext Cab w/ 5.3L. Modifications coming...
