Old 11-24-2003, 02:23 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Anyone heard of this or tried it?
I heard some guy saying that he had filled his stock motor mounts with silicone or something to make them feel stiffer, without having to upgrade the inserts. Has anyone ever heard of this, or had success with it, or is it just another stupid "I came up with this cool thing and only paid $3.35 for a tube of silicone..." type of thing? Just curious...
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 11-24-2003, 02:29 AM
Hybrid1990crx's Avatar
I never heard of that, and it sounds like a mess.
I can't see that doing anything, seeing that silicone dosen't really get that hard. Maybe it helps a tiny bit, but not much I'd say.
Old 11-24-2003, 02:40 AM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
i have heard of it...from a few places.
it will help a little. but why not just get the energy suspension motor mount inserts? Theyre only like $30...and if you really wanted to go crazy, you could fill the mounts with silicone, then install the inserts.
There's nary an animal alive that can outrun a greased Scotsman!
Old 11-24-2003, 03:01 AM
BullShifter's Avatar
Re: Anyone heard of this or tried it?
http://importnut.net/motormount.htm
I have the energy suspension inserts & my car vibrates like hell @ idle, too much for my taste. They do make a difference when it comes to traction, with out them my car wheel hops like hell. They are collecting dust right now.
Old 11-24-2003, 04:08 AM
91civicDXdude's Avatar
you dont use silicone, you use polyeurethane glue. its like $3.00 for enough to do all of the mounts. it makes them very stiff and also is a fix for a worn rubber mount.
Old 11-24-2003, 07:03 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
My friend uses muffler weld on his motor mounts in his saturn. It works pretty good for like a month and then it cracks and feels like normal, so he just puts more on. Looks like shit but actually works temporarily.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 11-24-2003, 09:31 AM
stealthZCcivic stealthZCcivic is offline
I actually did this on my front motor mount because it was ripped and my car would shake alot at idle, i took it out and packed it with silicone, been drivin it like this for 10,000 miles and its worked great, it doesnt shake and is pretty solid
Old 11-25-2003, 01:11 AM
4GZChatch's Avatar
so where do you pick up polyurethane glue? My mounts are not in great shape, but I don't want to put in a full energy kit... I just want to fix them up and improve it a little...
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 11-25-2003, 01:17 AM
auto parts store - hardware store
Old 11-25-2003, 01:36 AM
fyi..
the energy suspension kit is only an "add on" piece. They are inserts that go on either side of your stock mount. And like i said...theyre only like $30 for the d series set.
Old 11-25-2003, 02:24 AM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
http://homemadeturbo.com/tech_projec...nts/index.html
same thing i think
Old 11-25-2003, 07:40 AM
SiZ's Avatar
SiZ SiZ is offline
Keep your rubber ones!
I swear, poly bushings don't make the ride as nice. I fuckin' hate mine.
"The nympho of info, I'm fuckin' what ya heard"
Old 11-25-2003, 11:25 AM
Re: Re: Anyone heard of this or tried it?
I'm with SiZ, they suck for every day driving. Go with the inserts so if you don't like them, you can remove unlike the other methods talked about.
Old 11-25-2003, 09:08 PM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
Re: Re: Re: Anyone heard of this or tried it?
I used the stuff that is used to put windshields in. You have to put it in in layers for maximum set. If you goop it all in at once then it will have bubbles and never fully cure.
I get tired of hearing about how the ride quality sucks when you do this or that. If you want a smooth ride then go buy a Cadilliac. I know that everything I do is going to make the car vibrate, squeak and rattle. Thats why I have subs. Turn it up it all goes away.
Also I have done this cheap mod and I am now looking for a set of ES mount bushings and a new set of motor mounts. Thats tells you how well it worked for me.
Old 11-25-2003, 10:59 PM
FYI,
the energy suspension mount kit for the EF civic comes only with the front and rear mount inserts. the sides are supposed to be left stock. I guess the front and rear and considered "torque mounts" and since they have the most force acting upon them, they are the ones that need stiffening up.
If anything, Fill and front and rear only.
I personally have ES inserts and noticed no difference whatsoever, but friends of mine with the front mount filled and the rest stock say the engine is rock solid.
