Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-23-2003, 09:46 PM
johnsm johnsm is offline
gunning it
I just bought a used 2000 Isuzu Rodeo automatic transmission 3.2 v6. 70 000 kilometers. I have noticed that when i step too hard on the gas pedal the whole car shakes until you let off the gas. This does not happen when I accelerate at the speed limit or just above it. The car only shakes (only in 1st gear) when I floor it. To me this sound mechanically wrong. I'm calling the independant dealer who sold me the car to find out if it is a transmission problem. I would appreciate any experienced replies or expertise on the subject.
John
Old 11-24-2003, 06:55 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Re: gunning it
some ahops dont know how to check the fluid in these trannys in needs to be running in neutral if they are checking it with it in park all they are doing is letting fluid out of it. It does sound like either dirty fluid or a low fluid concern.
Old 12-01-2003, 01:27 AM
surferfletch surferfletch is offline
Re: gunning it
This is true! In the Haynes it lets you know that you top off through the overflow plug with the engine idling and at a tranny fluid temp of 90-135 degrees. No, I didn't get the special thermometer for the job! How bad, 2eye?
Old 12-01-2003, 01:39 AM
Re: gunning it
I just ran out to check the Haynes when I realized you said the fluid must be checked in NEUTRAL. It mentions shifting through the gears then returning to PARK to complete the topping off procedure. This is how I refilled the tranny. Do you suggest topping off with the tranny in neutral? Thanks.
Old 12-01-2003, 09:49 AM
Re: gunning it
only in neutral with the vehicle at operating temp running should you add to top it off
Old 12-01-2003, 12:47 PM
Re: gunning it
Thanks. I'll check it today!
Old 12-01-2003, 06:10 PM
rodeo02 rodeo02 is offline
I don't understand this park or neutral thing. I've always checked ATF level with the vehicle running & at normal operating temperature (on a level surface of course) and in park. What's the different between N or P in this situation? either way the tranny pump is still pumping & all the gearing is stationary. What am I missing?
THANKS!
Joel
Old 12-09-2003, 06:39 PM
Re: gunning it
It was a transmission fluid problem. I took it to a Mr. Lube outlet and had a broken seal on the drain plug replaced and the transmission flushed. After reading the replies here, I went back to the Mr. Lube and mentioned that they may have not preformed the flush properly. I told them that they had to top off the transmission while it was in neutral. There computer says the Isuzu has to be filled while running in park. They topped it off again while I had it in neutral and now it runs fine. The manager came out and started making a fuss saying thats the wrong way to do it. I talked to a mechanic who works on the occasional isuzu and he like the Haynes manual tops it off and test drives it. If he doesn't like it he adds more.
Ok, here is another question. I just recently had the engine oil replaced and flushed(not at the dealership) Now the check engine light has come on. Somebody I know says this happens to her mazda everytime she changes the oil and has an engine flush. Has anybody know this to be true of Isuzu's
John
Old 12-09-2003, 11:41 PM
Cat Fuzz Cat Fuzz is offline
I was told by a very experienced tranny guy that most newer trannies should not be flushed. Just drain and replace fluid. Can't remember his reasoning though.
17 inch brand new gun black,gun metal,gold and silver rims f/s $420.00 ig0twatun33d Introductions 0 07-21-2004 07:27 PM
Gun Control: Guns or Control? RedneckCarCrafter Politics, Investments & Current Affairs 108 09-02-2003 09:07 PM
