Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 11-23-2003, 07:30 PM
99GSR's Avatar
99GSR 99GSR is offline
Supercharger & Blowoff Valve
I was wondering if I could add a blowoff valve to my JR Supercharged integra gsr?
Old 11-23-2003, 07:47 PM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
huh? why? wtf?
Old 11-23-2003, 09:42 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Supercharger & Blowoff Valve
No you can not and it would be pointless if you could, but it is not possible.
Old 11-25-2003, 01:25 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
hehe, you should of just gotten a turbocharger so you can have the blowoff valve. hehe.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-26-2003, 01:02 AM
HONDABOND HONDABOND is offline
You technicaly could add one with some machine work (And it wouldnt be all that expensive iether) But as tran nsx says there is absolutley no point in doing it... If you had a vortec then it would be nessisary to allow the turbine in the centrifugical compressor to unwind without impeding the unit and causing alot of heating issues when the rpms fall or when shifting (Same difference) but a roots style blower usses two roots to compress air (Unlike the centrifugical blowers (Vortec-ProCharger) which basicaly use the compressor side of a turbo geared well) thats the only place I can think of were you would come up with this idea.
Personaly I think the Centrifugical blowers are alot better than the roots/skrew type blowers, sure the kits are an assload of money but lets talk about when you want some more power. You can easily unscrew the compressor wheel and upgrade to a different one or even change the entire housing itself! and turbocharger housings arent all that expensive (Althoe wheels can be) This will change allow you to tune for a certan powerband and if you want to go big and dont want to sacrafice low end boost you can upgrade the gearing... Verry simple verry reliable system, I know someone pushing 15PSI with one of these (Vortec) and making 350whp on a B16.
White folk eat noodles too.
