Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 11-23-2003, 02:03 PM
xsplinterx69 xsplinterx69 is offline
Unhappy 89 corvette starting problems
Hi, I'm new to the forum. I have an 89 corvette, but it wont start. I have installed a new fuel pump, starter, spark plugs. I took the original ones off because they didnt inject and put some on from a 91 camaro. I am going to put new fuel injectors. The car cranks great with the new starter, and there is fuel pressure in the fuel rail. I have squirtted starting fluid through the air box and it ignites it, but it does not start. The W.O.T. sensor has been checked and the regulator on the manifold. For a while air was being thrown out of the airbox instead of taken in. My compressions are low but enough to have a start or rough idle. The timing chain hasnt slipped and I'm totally stooped on what the problem is. There used to be water in the gas tank but i have pumped it out. When i checked the regulator that puts fuel back into the gas tank, it threw out water. CAN SOMEONE HELP ME? IS IT THE INJECTORS? thanks for any help.
Old 11-25-2003, 11:16 AM
lino asiatico lino asiatico is offline
Re: 89 corvette starting problems
Have you checked for spark? You might have a broken rotor or dirty cap, possibly a bad coil.
Old 11-26-2003, 09:27 AM
Yes i checked for spark, and there is.
Old 11-27-2003, 07:38 PM
TEXAS-HOTROD TEXAS-HOTROD is offline
water injection ?
How did you get so much water in the fuel tank? Was the car in a flood or something? Make sure that all the water is out of the system.
It runs on starting fluid, so that is a good sign. It has to be a fuel problem. The ignition module not only fires the coil but it also triggers the computer to fire the injectors. I have never seen Chevy injectors fail to the point to where it won't run, so don't change the injectors just yet.
If you have fuel coming out of the return line (back to the tank), then the fuel pressure should be good.
My advice is to replace the module with a known good one or break down and buy a new one (they can't be that expensive).
Hope this helps,
---TEX---
Old 11-28-2003, 08:25 PM
Im pretty sure i got most of the water out, there might be a small amount left, but not much. I have checked the injectors with noid lights, and they light when the computer sends the signal to let the fuel through. thanks for any help...........still stooped
Old 11-28-2003, 08:27 PM
Im not sure how the water got in there, but one day my dad was driving the car and the next it didnt want to start. It has been sitting for a while here and there though.
Old 04-02-2004, 12:42 PM
jlemaitre1 jlemaitre1 is offline
try checking your D.I.S., direct ignition system mod. it's about $80.00
Old 10-22-2004, 08:22 PM
jetweb jetweb is offline
I had water in my tank one morning on the orad
it gets in from yhe gas cap
if the drain is clogged and you had the car running it creates a vacume
then the water fills up past the cap and sucks it in the hole
i was under waranntee then and they sucked it out
they had to use an additive not sure what it was but it dries the fuel and adsorbs the water
tetrohydrosomething
water is not good
check the filter under the car
it is a big AC can
v70 awd starting problem hot and cold jonnylove V70 0 05-13-2010 04:04 AM
98 Cherokee Starting Problems cdmonday Cherokee 4 01-22-2010 11:13 AM
98 Cherokee Starting Problems cdmonday Cherokee 1 01-21-2010 07:08 AM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
1995 Corvette starting problems jammer499 Corvette 0 07-01-2007 11:24 PM
