Old 11-23-2003, 11:21 AM
Touge180 Touge180 is offline
Did i do something wrong
okay a couple of days ago i decide to check m spark plugs and i found that the one of the Bosch Super Plugs was f#### so i decided to goto advanced and get some more only they didn't have any so i got NGK plugs with copper core and when i put them in and test drove it when i acclerated their was a clicking noise come from the engine bay si i finally founds a place with the super plugs and got those and the clicking is still their.
My car doesn't look fast and my car doesn't look furious...so when you see my taillights fade into the distance, remember this: I was into cars long before you and the rest of the trend-humping lemmings showed up and I'll be into cars long after you move on to the next pop-culture trend that you decide to shamelessly bastardize
Old 11-23-2003, 12:19 PM
91civicDXdude's Avatar
dont use bosch plugs. look under your hood. it will say to use NGK. ONLY USE NGK WITH HONDAS.
Old 11-23-2003, 01:22 PM
Hybrid1990crx's Avatar
Really?
Old 11-23-2003, 02:16 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
i agree bosch is not good for honda motors use OEM NGK plugs
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 11-23-2003, 02:45 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
yea i'll agree i used the platium +2s there ok but now i'm using NGK iriduims lot nicer i'm going to keep with NGKs from now on. Also FUJI heavy plugs rule there JDM only unless you get subie plugs all the mechainces *sp* near me say subies plugs are teh bomb.
Old 11-23-2003, 03:59 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
Re: Did i do something wrong
well i saw a test that someone did between busch plats and iridiums and the plats gave a slightly better power increase
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 11-23-2003, 04:09 PM
BullShifter's Avatar
Re: Re: Did i do something wrong
Dyno tests:
http://www.importreview.com/reviews/densoVSbosch.html
http://www.importreview.com/reviews/BoschVSNGK.html
http://www.importreview.com/performance.html
Old 11-23-2003, 04:23 PM
Jay eS Iye's Avatar
those are it they weren't better than the denso, but very very very close. better than NGK however, i'm glad i found that before i bought them
Old 11-24-2003, 09:50 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
What's the big deal which brand you use? There are obvious differences between regular copper, Platinum, Iridium, and Gold Palladium plugs. But for regular applications any brand plug will do a good job. They are all high quality products. In my opinion, one of the reasons Honda recommends NGK or ND (Nippon Denso) spark plugs is Honda is a Japanese company and they want you to use Japanese parts to keep Japanese workers employed (or money rolling into Japanese companies) which is perfectly acceptable. The other possible reason is the label under the hood was probably printed in Japan (or the information for the label came from the Japanese HQ) and they referenced easliy sourced part numbers. I don't think they would bother looking around for the Champion part numbers, especially if those parts are hard to come by in Japan. To say use only NGK in a Honda is a little short sighted.
BTY, I'm using Autolite plugs and she runs great.
Old 11-24-2003, 10:54 AM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
I was told not to use Bosch plugs on my Honda because they get too hot and can melt the threads in the head (that the plug screws into). I've always used NGK's anyway.
Old 11-24-2003, 12:21 PM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
In response to the clicking noise, I'm not an expert, but check your timing. I had the same problem and I retarded my timing and it went away. The cheapest easiest way to mess with your timing is to rotate your distributor. You can loosen the 3 10 mm bolts that hold it to the engine and either advance or retard it by toggling it towards the bay or away from the bay and re tightening the bolts. You might have to do it several times before you find the right position.... Like I said though... this worked for me when I heard clicking noises and havent heard them since. Dont know what your situation is though.
Peace,
Vince
