Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 11-22-2003, 10:49 PM
Klementine Klementine is offline
2003 Keyless remote for Yukon
I need to learn how to reprogram a keyless remote. Any help will be appreciated. Thanks
Old 11-23-2003, 03:19 PM
99ssconv 99ssconv is offline
Important
Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
There are 3 methods for programming transmitters, which are listed below as methods 1-3. Up to 4 transmitters may be programmed to the passenger door module (PDM). Each programmed transmitter is given a position of #1-#4 in the PDM memory.
Method 1 - No Tools Required, Program All Transmitters
Important
All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter.
The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only; #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available.
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to 4 transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
Operate the transmitter functions in order to verify correct system operation.
Method 2 - Scan Tool Required, Program Individual Transmitter
Important
Only use this option if you are certain which transmitter, #1-#4, is being replaced, or the new transmitter can be programmed into a previously unused position within the PDM memory.
Install a scan tool.
Turn the ignition ON, with the engine OFF.
Use the scan tool in order to access the passenger door module Special Function menu.
Select Program Individual Key Fob to program specific transmitters.
Follow the directions on the scan tool in order to program the transmitter or transmitters.
Method 3 - Scan Tool Required, Program All Transmitters
Important
Select Program All Key Fobs to clear the PDM memory.
Follow the directions on the scan tool in order to program the transmitters.
Old 11-23-2003, 03:20 PM
Resynchronization may be necessary due to the security method used by the remote keyless entry system. The transmitter does not send the same signal twice to the passenger door module (PDM).
The PDM will not respond to a signal that has been sent previously. This prevents anyone from recording and playing back the signal from the transmitter.
The panic button should still operate normally when the system is out of synchronization.
Resynchronization may be necessary under the following conditions:
The battery in the transmitter is very weak.
The battery in the transmitter was replaced.
The battery in the vehicle has been in a low or no charge condition for an extended period of time.
In order to resynchronize the transmitter with the PDM, perform the following steps:
Stand within 1.5 meters (5 ft) from the vehicle.
Simultaneously press and hold the LOCK and UNLOCK buttons on the transmitter for 7 seconds.The door locks should cycle in order to confirm resynchronization.
