Old 11-22-2003, 08:19 PM
pardinkle pardinkle is offline
Send a message via AIM to pardinkle
Question sterio wiring
hey guys. this site looks impressive and it seems that maybe someone here can help me out. i have a 97 cavalier z24 and im trying to splice a cd player into it. it's a pioneer. dumbass me cut the harness off of the car cause ive wired a lot of sterios, but i never ran into this problem before. on the harness that plugs into my cd player, i have a fat yellow wire, a red wire, a black wire, a remote wire, and then 4 sets of speaker wires. but the part that is getting me is the wires on the car itself. there are two gray wires, two yellow wires, a tan wire, a black wire, two brown wire (one is larger than the other), a light blue wire and a dark blue wire, a dark green wire and a light green wire, a orange wire with a white stripe on it, a green wire with a white strip on it. what goes to what? i cannot get it to work and i wasn't sure if someone had reference to the which wires are which. ANY help would be greatly appreciated....
Old 11-22-2003, 11:21 PM
wutangteo wutangteo is offline
Re: sterio wiring
here i found this is an old post on this site, give credit to rich for this, ima just repost it for you, and I'm sure it should work on your cavalier because i have a 2000 cavalier and the wirings seem like the same, so
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Front Speakers : 4" x 6" Doors
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers : 6" x 9" Rear Deck
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Old 11-24-2003, 12:08 AM
Talking AWESOME, but one more thing if you know...
dude. sweet. if this works i owe you one big time. ill post a reply to let you know.... but do you know what the green wire with a white strip is for? does it have anything to do with the theft lock or something? oh, and now my little remote door opener and shit doesn't work, nor does my dome light? does that have anything to do with my sterio being dissconnected? i just bought this car and im kinda just going into it blind, so i do appreciate you guys helpin me out here...
Old 11-25-2003, 07:21 PM
Necrofiend Necrofiend is offline
Send a message via ICQ to Necrofiend Send a message via AIM to Necrofiend
the other wire should be for stock amp, atleast thats what i think it should be because mine has a stock amp. and as far as your other stuff not working.....consider yourself very lucky. because cutting the connections to the radio could have disabled your entire car....the entire wiring harness and ECU runs through the radio and you can lose many things when removing the radio. bes buy, tweeter, and any other aftermarket audio shop wont touch cavalier for this reason. too high risk of disaster. entire wiring harnesses have melted down and been needed to be replaced before. most people need to leave the stock readio hooked up without the speaker wire attached, just power and stuff. and hidden down inside of the dash, and wires spliced off to the aftermarket head unit in order for their vehicle to work! so like i said you only lost dome lights and Keyless Entry your quite lucky!
Old 04-09-2004, 08:24 PM
cm467 cm467 is offline
Re: sterio wiring
I bought a wiring harness for the radio ($17) for a 1988-UP GM vehicles. I verified it with the harness manufacturer that this harness fits a 1997 Cavalier.
Well here are the color codes from the harness itself...
Yellow - 12 VOLT Battery / Constant (12V+)
Red - 12 Volt IGNITION/SWITCHED (12V+)
BLUE - Power Antenna
BLUE/WHITE - Remote turn on (12V+)
Orange - Illumination/Dimmer
Speakers
Black - chassis ground (12V-)
White - Left Front Positive (LF+)
White/Blk - Left Front Neg (LF-)
Gray - Right Front POS (RF+)
Gray/Black- Right Front NEG (RF-)
Green - Left Rear POS (LR+)
Green/Black - Left Rear NEG (LR-)
Violet - Right rear POS (RR+)
Violet/Black - Right rear NEG (RR-)
www.scosche.com partno: BBGM02AB - 1988 & UP GM
you can call Tech Support 800-621-3695 x3
Old 04-10-2004, 08:56 AM
Three_Fingers Three_Fingers is offline
Re: sterio wiring
ECM does NOT run thru the radio harness...tch...tch..misinformation...
The only thing that goes to the car from the ECM is the MIL light and the ALDL.
