Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-22-2003, 09:05 PM
austinrodeo austinrodeo is offline
Changing the Axle Oil?
My rodeo is approaching the 60K mile marker and I am debating on the wisdom of changing the axle oil again (I did it once at 30K miles.) The owners manual recommends doing it every 30 K miles. But all other non Isuzu service shops I've consulted said that most vehicles never need that done before 120K miles. Some said that they had had 4wd vehicles they regularly maintained into 200K mile range that never had nor needed the axle oil changed? Is this a necessary maintenance or is just another way to spend several hundred bucks that I don't have?
Thanks
Andy
Old 11-23-2003, 10:56 AM
rodeo02 rodeo02 is offline
Andy- A typical dealer charge for a front & rear axle lube changeout is under $100. The rear axle requires a tube of limited slip additive that I would not get anywhere but from an isuzu dealer. The axles are covered under the 10yr/120Kmi warranty, so if you ever have an issue with them, the dealer may want to see proof of maintenance. You can make this a fairly easy DIY project & save the receipts, but the dealer will pull the rear diff. cover & do a thourough job for you. This is one of those jobs I don't mind paying the dealer to do for me!
G/luck
Joel
Old 11-23-2003, 07:29 PM
surferfletch surferfletch is offline
Re: Changing the Axle Oil?
This is one of those jobs that I know my buddy would say, "Change the fluid - what for?" Flipping through the Haynes manual, though, it looks like an easy job. I think I'm going to treat the Rodeo to a tranny fluid and filter change, and an axle oil change this holiday weekend.
Old 11-23-2003, 08:45 PM
You have a Haynes Manual for a late model Rodeo? (2000+?) If so, where did you find it? I called the usual suspects looking for one, Pep Boys, Auto Zone, local bookstore and Library. no luck.
I think I'm entering the post warranty phase when a rodeo shop book would be real helpful.
Old 11-23-2003, 08:55 PM
rodeonewbie rodeonewbie is offline
i found a Haynes at autozone maybe ask them to order you one its worth a shot
Old 11-24-2003, 01:19 PM
Yeah. It was either Autozone or Discount.
Old 11-24-2003, 01:20 PM
But mine is a '97...
Old 11-27-2003, 08:14 PM
mwt mwt is offline
What is the skinny on the limited slip additive. I jsut changed mine and used MOBIL 1 synthetic
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 09:39 PM
