Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 11-22-2003, 06:56 PM
aplitkin aplitkin is offline
Angry 87' Nissan 4x4 Accelaration problems
My Hardbody with the Z24i 4 cyl Motor idles great, but when I try to accelerate it lurches and sputers. Trying to accelerate up a hill is impossible. If I really try to put my foot into it when it does this I can smell un-burnt fuel. If I baby it it will go. Already replaced the fuel filter and plugs but didn't change anything. Any suggestions to a fix would be great. The only thing I think it might be is either the fuel pump or fuel pressure reg? If anybody else has any idea please let me know! I don't want to just start swapping parts as they are quite expensive. HELP!
Old 12-06-2003, 11:07 PM
colortech colortech is offline
Re: 87' Nissan 4x4 Accelaration problems
I am having the same problem with my 86 Nissan 2wd pickup. Same engine same problem. Does adding carb cleaner help any? It gives me a small amount of improvement, or could be just coincidence..... Give it a try, and let me know.
Old 12-26-2003, 12:45 AM
UncleGus UncleGus is offline
Re: Re: 87' Nissan 4x4 Accelaration problems
Just a thought. Have either of you inspected the distributor cap and rotor. The cap has a tendency to wear one coil post inside the cap more than the other. If you have the "craziness", while engine is running pull one coil wire off at the distributor end at a time to see if the engine rpm drops evenly and spark kv is close to equal between the two.
U.G.
Old 12-29-2003, 01:29 PM
Arkemn Arkemn is offline
Send a message via MSN to Arkemn
lawnmower sound
have you had your exhuast changed since the truck was new if not could be cloged converter only if it sounds like a reved up push mower when idleing
Razors burn and so do tires
