Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 11-22-2003, 11:14 AM
kickflip59 kickflip59 is offline
Send a message via AIM to kickflip59
fuel gauge broken 95 bonneville
i just bought a 95 bonneville se. the fuel gauge stays past the full mark. does anyone know how to fix this problem?
Old 11-22-2003, 01:44 PM
markwb's Avatar
markwb markwb is offline
Re: fuel gauge broken
It may not be a simple fix, or an inexpensive fix either. It could possibly be the fuel sender on the tank. I had one fail on my 97 Bonneville, too costly to repair. I mainly use the trip meter every fill up, then at approx. 300 miles fill up again. Utilize your knowledge of the car (fuel usage) in conjunction with your driving habits and the trip meter method can be a good tell-tale indicator on how much fuel is in the tank.
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
Old 09-27-2004, 02:27 PM
02bonne 02bonne is offline
It's the fuel pressure sensor most likely. Bonneville's have always had problems with them. My 2002 bonneville had a recall on the sensors!
Old 11-17-2007, 06:52 PM
fuelmaxman fuelmaxman is offline
first i have heard of this fuel pressure switch, i have a 97 bonneville that the sending unit failed in. i took one out of a 96 and rebuilt it,(new lines) but now the gauge sits below empty. i had a huge fuel leak in the pressure line when i re-installed the tank, but i think the gauge should still function properly. can you let me know if you think that the switch you speak of could have anything to do with my problem or is it possibly because the sending unit fuel feelers were slightly different between the 96 and 97. could this be a power or ground issue in the white/black wire or the purple wire? kind of frustrated and not as farmiliar with these as the earleir ones. thanks man
01 2500 8.1 Suburban Fuel Gauge Issue aptivaa12 Suburban 2 08-25-2010 07:47 AM
2000 Sportage Fuel Gauge Not Working...HELP!! hottmpr80 Sportage 1 08-03-2010 08:35 AM
Temperature and Fuel Gauge = Dead TESE Malibu 3 02-22-2010 06:45 PM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
'04 Tahoe Range/Fuel gauge problem. usn_622 Tahoe 2 02-21-2009 09:58 PM
