Old 11-22-2003, 10:01 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Question Lights and locks
Ok, I need some kind of final answer. I've been told so many different things by so many people, I have to get this straightened out. I have a 99 silverado Z. For some reason, the 99 will not let you cut the headlights off at night, no matter how many times you push the override button, nor will it let you change the doors locking at 20 MPH. I asked the mechanic at the GMC place if he had ever changed any of this w the computer there at the shop. He said that he knew for a 99 he could change the "rolling locks", but had never heard of being able to give me the option to turn my headlights off manually. Which is real, because I hate not being able to cut my headlights off unless I turn the truck off. Is it possible for the GM people to re-program my truck to do this, or am I just SOL?
Old 11-22-2003, 02:19 PM
yoskater yoskater is offline
Talking
my friends and i figured out how to turn them off at night a few years ago
you push your dome light (the little circle button next to your headlight switch) 4 times.
1.. 2.. 3.. 4 and your headlights turn off
push it 4 more times to to them back on.
It's not as easy as swithing em on and off but you get used to it.
good luck!
Old 11-23-2003, 09:29 AM
sc_customs's Avatar
sc_customs sc_customs is offline
Send a message via AIM to sc_customs Send a message via MSN to sc_customs
Re: Lights and locks
good luck!
doesn't work on 99 models. 2000 and up. R&D automotive makes a headlight override kit that you can install that allows you to manually control your lights with the switch
______________________________
2000 Silverado 4.8L V8 (Converted from 4.3L V6)
Edelbrock Ceramic Coated Headers
K&N Fipk Gen. II
Superchips MAX Tuner
Flowmaster 40 Series DF w/3" pipe
Poweraid TB Spacer
Flex-a-lite Electric Fans
3.73 gears w/Eaton posi
Whipple on hold
And those are just the performance mods...
Old 11-23-2003, 11:14 PM
jeverett's Avatar
That kit sounds kinda like what I want. I've also been told that if I un-hook the sensor in the dash and use a jumper wire to complete the circuit, that the auto-lights would be disabled. Is this true? I'm talking to another Chevy dealership in the morning and raking them over the coals..
Old 11-24-2003, 12:07 PM
sc_customs's Avatar
I've heard of that...but I don't really like the idea of splicing wires.
Plus it may or may not work. If it doesn't, then you have no sensor and your lights would most likely stay on constant.
K&N Fipk Gen. II
Poweraid TB Spacer
Whipple on hold
Old 11-24-2003, 07:29 PM
jeverett's Avatar
I went to a "Good" GM place today, and they told me that to get to the sensor, I'd have to take the dash pad off which I'm not doing. As far as the locks, they said that they could program it, but it would take as long as an hour and a half and probably around $125 which I can spend on a cool air intake...I believe I've caught shaft.
Old 11-27-2003, 08:37 PM
NWChevyGuy's Avatar
NWChevyGuy NWChevyGuy is offline
My Buddy had a 98 S10. We just pulled out the automatic headlight Relay out of the relay box under the hood. Just had to turn them on manually from then on.
Old 11-27-2003, 11:55 PM
sc_customs's Avatar
ahh, 1 of the numerous differences between the Silverado and the S-10.
K&N Fipk Gen. II
Poweraid TB Spacer
Whipple on hold
Old 11-29-2003, 08:30 AM
jeverett's Avatar
Man, I wish it was that easy..oh well.
Old 01-25-2004, 11:40 PM
jonjonwells jonjonwells is offline
Send a message via AIM to jonjonwells Send a message via MSN to jonjonwells
As to using a jumper to bypass the auto light system. It will NOT work. The system requires a voltage to pass at all times through the wire. The varying amount of voltage is what tells the sensor to turn the lights on or off. The are two ways to replicate this. The first and easiest, though sloppy, is to install a light underdash. When the truck is turned on, the light bulb will turn on, tricking the sensor. The second way, is to remove the sensor and put a variable resistor in it's place. By adjusting the POT you will be able to send the correct amount of voltage to the system to make it think that it is daytime all the time.
Old 01-26-2004, 02:10 AM
Slowprocess's Avatar
Slowprocess Slowprocess is offline
Send a message via Yahoo to Slowprocess
If you want to just cut them off while sitting still(I learned this while parking out in the country ) Just barely push down on the emergency brake, turn the truck off, then cut it back on. The lights will be off until you release the brake, then they cut back on.
Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires
Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft
Old 01-26-2004, 08:11 AM
jeverett's Avatar
I really like having the option of having full-control of the lights IF I want, but also having the option of letting them control themselves. That R&D thing sounds exactly like what I want, but I cannot find it anywhere.
Old 04-16-2004, 06:47 PM
markgent markgent is offline
Talking Re: Lights and locks
[quote=yoskater]my friends and i figured out how to turn them off at night a few years ago
good luck
Once you have operated the dome light so that the lights are off you can manually control them with the light switch! Give it a try
Old 04-16-2004, 07:31 PM
jeverett's Avatar
Since I first posted, I've found out how to permanently disable the auto-light feature. I cut the 2 wires that ran from the sensor in the dash, about 2 inches from the plug ont he BCM. I then wired a 1/2 watt, 1.5K ohm resistor between the wires. No MORE AUTOLIGHTS!!!
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-17-2004, 01:45 AM
buttnekked buttnekked is offline
with a little thought a dpdt switch could be inlined to bypass resistor to allow auto feature. Leads from Bcm to middle poles. resistor between poles on one side, sensor on poles on opposite side. flip switch to override (with resistor) or allow (sensor) auto lights. switch could then be mounted out of site. say in center console or ashtray.
brake light and dashboard cleaning sailor86 Engineering/ Technical 4 12-29-2009 07:40 AM
Taurus transmission light and problems mikecorki Taurus | Taurus Wagon 4 06-01-2009 06:39 AM
new battery put in now interior lights and locks wont work stutor007 Envoy 3 01-16-2009 06:32 PM
1998 Oldsmobile 88 interior lights and locks not working Danfrankhank Eighty Eight 0 03-11-2005 06:28 PM
anti lock brake, brake, traction control light and service vehicle soon lights all on aivideo Regal 4 09-09-2004 03:22 PM
