Old 11-22-2003, 09:16 AM
madmustang madmustang is offline
Keyless Entry
i just bought a 99 escort SE and received very little information on it from the prior owner. is there a way to tell if it already is set up for keyless entry. I did not recieve any remotes with the car.
If it is set up for keyless, can I buy a remote that will be programmable for this car?
thanks
Old 06-16-2004, 01:18 AM
hzlallsmiles hzlallsmiles is offline
Send a message via AIM to hzlallsmiles Send a message via Yahoo to hzlallsmiles
Keyless Entry
The way to find out if your car is equiped with keyless entry is to try this. what you do is get into your car and close all the doors then insert the key in the ign. rotate the key to the on but not start position 4 time within 10 seconds if it works the locks should lock and unlock by them self. if that does not work then try the same for 5 rotation 6,and 8. and remember do not crank the engine at any time if you do restart by starting the engine and opening and closing the door. if the door locks lock and unlock in any of the rotations your car is equiped with the keyless entry. And if you want to buy the remote contact you local locksmith or me and I will give you a location where you can get one cheaper then the dealer. Good luck and let me now how it worked out for you.
hzlallsmiles
(Locksmith)
Old 07-13-2004, 11:49 PM
96scort 96scort is offline
Re: Keyless Entry
the same thing happend to me and i just went to a speaker store (advandced audio) bought a key pad and a friend programed it email me at [email protected] and i will get the papers outta my car and give you the site
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
1998 Toyota Avalon XLS Keyless Entry Programming Instructions kattate09 Avalon/Pronard 1 02-04-2010 04:58 AM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
06 Camry LE - How to program keyless entry pshrivas Camry/Camry Hybrid/Vista 0 03-20-2009 02:54 PM
