Old 11-21-2003, 10:19 PM
blacksheep blacksheep is offline
Send a message via Yahoo to blacksheep
Crankshaft pulley nut
i needs some help i cant get the crankshaft pulley nut off, first off in the repair manual it doesnt say what direction is loosen and it says to stick a screwdriver into the fly wheel but i cant find the spot to do that and any tips would help
it better get me to wyoming
Old 11-22-2003, 12:35 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Re: Crankshaft pulley nut
Yeah, that one can be a serious pain to get off. First, it goes lefty loosey like most of them do...
Second, is the engine in the car or out? My Z6 was out of the car, and what worked for me was to Jam a prybar between the flywheel and block so that it will run into the teeth when the flywheel tries to turn. Then we stuck a second prybar between the first one and the block to increase the tension. Then, my buddy knelt on the motor while pushing down on the intake manny while I stood on the 24" breaker bar with a jack handle on the end of it while pushing down on the intake manny. This one was on with like 700 ft lbs of torque, I swear! Hopefully, yours isn't as bad, but if all else fails, you can heat it up some with a torch, spray some penetrating oil on it and let it sit for a while, and go pray while it sits! If you have access to air tools, just put the air gun on there and hammer away at it until it breaks loose, and wear some earplugs!
Good luck!
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 11-22-2003, 12:53 AM
BullShifter's Avatar
Re: Re: Crankshaft pulley nut
The easiest way to loosen it is with a impact. Usually we use a 3/4" impact @ work & even that struggles on some - them mofos get tight! It's not reverse thread
Old 11-22-2003, 06:53 PM
Mojoe Mojoe is offline
Place a 2" nut in the hub, stick the socket for the crankshaft bolt thru the 2" nut hole, hold the 2" nut with a big crescent or a 2" wrench. Turn the crankshaft bolt counterclockwise to loosen.
Old 11-22-2003, 09:34 PM
spayordie spayordie is offline
so does the 2" nut just act to keep the socket centered, or am I missing some physics voodoo here?
Old 11-22-2003, 10:58 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
all im saying is 600ft/lbs baby, and that shit came right off.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-23-2003, 12:11 AM
cot's Avatar
cot cot is offline
be careful! we tried to block the pulley from turning by putting abolt through it and we chipped the pulley
but a rented electric impact took the mofo right off, even without chocking the pulley
just rent the biggest one you can get
Old 11-23-2003, 12:38 AM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
dude to lock the flywheel take off the starter and then you can wedge a screwdriver in there. then take and impact or a breaker bar and push like non other
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 11-23-2003, 02:44 PM
Mat Hadder Mat Hadder is offline
Seriously, you are going to need an impact wrench. Another trick is heating it up with a torch. I found that after heating it up, it came off much easier. Good luck.
Old 11-23-2003, 03:46 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Don't use anything to jam in the flywheel then you might end up having to buy a new flywheel. Rent an impact if you don't know of anybody with one you can borrow.
Check out my car here My 91 Hatch
Old 11-23-2003, 07:37 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
can't u just put the car in gear? Then the crankshaft won't move right? like put it in 5th gear or something...just a thought. Whenever I have a problem taking something off, I just put on a breaker bar and then use the pipe from a floor jack. If that doesn't work...go to a junkyard and get a pipe cut to like 30 feet. Then that bitch will come off!!!
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 11-23-2003, 07:41 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Heating the bolt up can cause damage to your crank.
You know, they make a tool specifically for this purpose, which allows you to break it loose with a two 3/4" rachets, or breaker bars. The tool costs $40, or usually can be rented.
Old 11-23-2003, 08:15 PM
You could try putting it in gear while the car is on the ground - 1st or reverse not 5th. Next time you park on a hill - put it in 5th without the ebrake, your car will roll, not so in 1st or reverse.
Just use an impact and be done with it!
Old 11-23-2003, 11:10 PM
cot's Avatar
cot cot is offline
I'm pretty sure you want it in the highest gear, not the lowest
when you park, you put it in a low gear, because you want turning the wheel to be at a mechanical disadvantage relative to turning the engine over, which means that the engine would be at an advantage for turning the wheel. this occurs at the lowest gearing, where the engine will spin the tires with lower speed, but more torque.
when you're turning the pulley, you want the engine to be at a mechanical disadvantage relative to the wheels, which occurs at the highest gear, because there the engine turns the wheels at the highest speed but with the lowest torque
Old 11-23-2003, 11:20 PM
Im not talking about turning the pulley - Were talking about removing the bolt.
