Old 11-21-2003, 04:17 PM
Beeson Beeson is offline
Heater not working
Hello,
I have a 1999 Sub and the heater quit working. The A/C works fine, the fan works fine, just no heat. Dampers? Heater Core?(I doubt it). Thanks in advance.
-Beeson
Old 11-23-2003, 02:38 PM
99ssconv 99ssconv is offline
does the radiator have coolant in it?
Old 11-24-2003, 06:35 AM
jfmctlaw jfmctlaw is offline
Re: Heater not working
Does your rear heater work? This would show the water pump is pumping hot water into the circuit.
If you call for heat in the front unit (by turning on the fan and selecting a hot temp) can you detect any heat from the heater core? Feel the heater hoses in the engine compartment all the way to the firewall.
Do you hear the dampers switch positions when you change flow direction settings such as def to floor? (Dampers shouldn't have much to do with this as they leak anyways and you'll feel heat out of the Def when you set them to Floor.
Heater cores don't usually clog so early in life ('99) but it can depend on how clean your cooling system is. Did you do anything to your cooling system in the last 6 months?
Jim
Old 11-24-2003, 09:01 AM
Fixed it
That was it! I took it over to a friend's house (a chevy nut) and he put more coolant in it and...viola! We have heat! Thanks guys.
=-Brigham
xantia heater fan/back window heater not working alan hughes Xantia 2 02-04-2009 12:18 PM
Replaced Heater Core... now wipers, headlight, heater not working odsska Thunderbird 4 02-03-2006 12:59 PM
heater not working does not over heat temp gage not registering/ show temp sgtmaj9999 Grand Marquis 1 11-25-2005 10:03 PM
Heater NOT working?!?? rtigert Viper | Viper SRT19 Roadster 2 09-10-2003 12:16 AM
heater not working jimismoove Prelude 0 08-30-2003 12:50 AM
