Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 11-21-2003, 10:35 AM
mutsie mutsie is offline
Question ABS light
I have a 99 malibu with an ABS light that comes on when turning corners. This only happens about once a week and the light turns off as soon as you stop then restart the engine. There are no apparent loose connectors or chaffed wires. I changed the front pads and completly flushed the system 12 months ago but the problem persists. I consider electrical problems "fun" but I am not sure where to start with this one. There seems to be a wealth of experience and information on this board and I was wondering if anybody had any suggestions?????
Old 11-21-2003, 10:41 AM
RABarrett RABarrett is offline
Re: ABS light
This is likely a connection issue on the ABS sensors on the affected wheels. When turning corners, the ABS loses the wheel readings, setting the code and lighting the light. Ray
Old 11-21-2003, 11:08 AM
Re: ABS light
Is this a common problem?? Is there a test for resistance and voltage on these sensors???
Old 11-23-2003, 07:09 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: ABS light
Most likely the problem is going to be in the front....When the ABS light comes on, it stores a code that will help with diagnostics....especially what corner the problem is happening in....
The resistance reading of a WSS on your vehicle should be 1040-1160 ohms.
and when turning the hub assembly by hand, you should get about 100 mv A/C voltage.
From experiance, I find a lot of intermittant ABS concerns are caused by the jumper harness from the sensor to the main body harness.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-26-2003, 01:17 AM
DarkChobit DarkChobit is offline
i just thought of one more thing u might want to check. i've seen someone have a similar problem before. check the tire sizes to make sure all tires are the correct size. if one tire is different than the other three, the computer has a problem keeping track of the revolutions of the tires. (note: when changing tires sizes, you must have the car's computer recalibrated to the new size or else you will get bad readings from things like the odometer and such.)
Old 11-26-2003, 10:01 PM
99ssconv 99ssconv is offline
probably have a wire broken inside the insulation on the jumper harness at the lower control arm, disconnect connector and measure resistance across connector, tug on the wires and watch meter for open, if you knew the code you would know which side to test.
Old 03-19-2004, 12:51 PM
timd timd is offline
Re: ABS light
You mentioned a different sized tire may cause an ABS light. What about a tire low on air???????
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 11:27 AM
'95 Town car ABS light on and hesitation olopezm Town Car 5 12-02-2010 07:30 PM
2000 Alero 3.4 ABS light on, code c1265 skeeter123 Alero 8 01-26-2010 08:51 AM
95 silverado abs light is on and smells like brakes joseriverasg Silverado 2 12-21-2009 11:15 AM
98 bleeding brakes/ABS light comes on PHXAuto Intrigue 2 09-28-2009 09:51 AM
