Old 11-20-2003, 11:54 PM
Slacky Slacky is offline
Send a message via AIM to Slacky
Coolant leak
I have a coolant problem. My car overheats, and when I shut the engine off, tons of coolant leaks from either the radiator, or the lower hose.? What would cause this, water pump? what?
Please help, no one would answer in CRX forum, bastards.....
Brian
90 Honda CRX swapped b16
Old 11-21-2003, 12:43 AM
KC Ron Carter KC Ron Carter is offline
after it is shut off
Usually if the issue is after the car is shut off it is the pressure cap.
It is normal for the coolant to get hotter after the shut down.
But the pressure cap is supposed to keep the coolant in the system.
There should be an overflow tank that is also there to catch any overflow.
I hope this helps.
Later,
Old 11-21-2003, 09:26 AM
Well my car overheats, while it is running, not after the car is shut off. The coolant starts leaking after the car shuts off
Old 11-21-2003, 01:56 PM
mechy1barry mechy1barry is offline
Re: Coolant leak
does the fan cut in on time?-other, start car with coolant cap removed,does the coolant overflow then?-other,water pump impeller detatched/head gasket/blocked radiator.
Old 11-22-2003, 02:07 PM
Fan works, with cap removed it starts to overflow, then after shut off is dumps it from under the rad. Would this be caused by a stuck thermostat?
Old 11-23-2003, 03:53 AM
Unhappy Re: Re: Coolant leak
it would seem that the water being dumped is coming from the over flow pipe,most likely you have a head gasket problem,have it pressure tested,off,and running.
Old 11-29-2003, 03:46 PM
bm2boats's Avatar
bm2boats bm2boats is offline
I agree with Barry. I think it is your head gasket. get the system pressure tested. Also check your oil the next time you change it. Do you see any hints of coolant/ water?
Old 11-29-2003, 06:13 PM
Deniz Deniz is offline
when my mazda 323 overheated last month, the diagnose and pressure test indicated that my water pump was shot, head was warped and gasket was gone.. It was an expensive 10h labour( $1000cad) fix. So i dumped the car.
make sure its not leaking from the water pump.
Old 12-06-2003, 02:48 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
i had the same proble, it was the head gaskit, replace that and check the water pump as well. the crx forum is pretty much dead, im not sure why i keep checking it. if u have any other honda related questions go to the "Lets Get Technical" section in Honda/Acura. lots of honda guys there who will know your car
Old 01-16-2004, 01:40 PM
John Chang John Chang is offline
Re: Coolant leak
Car 1991 Civic SI
I have coolant blowing out through the resorvoir.
Car doesn't overheat - but I have to put coolanty in the car daily. Some oil in the resorvoir and no coolant in the oil pan.
Garage has pulled the head and says head gasket OK and head OK. They seem to think that the problem is with the block and suggest that I change engines.
Any suggestions as to what the problem can be (other than a problem with the block) or what other things (tests) I should have them do before I am satisfied that it is indeed the block.
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 04:02 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
2001 Chevy Cavalier Coolant System Problem getwilde Cavalier Problem Diagnosis 0 09-18-2009 06:43 PM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 10:20 PM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 04:17 PM
