Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 11-20-2003, 10:19 PM
ibtopcop ibtopcop is offline
Angry 95 Bonn Wont Start Warm
i have a 95 Bonneville runs great and starts great when cold. If I drive it enough for it to full warm up and then leave it parked for 30min to 1 1/2 hour It wont start. When I try to start it it acts like it gona run but almost instantly starts to misfire terrible, most of the time it quites, but every once in a while it will misfire for about 15sec then gradualy come to a idle. Once running it has no problems at all. I have checked fuel pressure, new plugs and wires, and checked for vacume in the gas tank. Any help would be greatly appreciated.
Old 11-20-2003, 10:41 PM
MRWSM's Avatar
MRWSM MRWSM is offline
Re: 95 Bonn Wont Start Warm
Try the coil, I have seen mystery's like this solved by replacing the ignition coil. They can often not work properly when heated up. Good luck.
Old 11-22-2003, 11:09 PM
Thank you for your reply, but the coils have been eliminated.
Old 11-24-2003, 11:12 AM
bridget36907's Avatar
bridget36907 bridget36907 is offline
It may be the crank sensor I had this same problem with my 94 bonnie..when warm it won't start..it just cranks and crankns and cranks..after about 30 minutes-2 hours..it will start and run like nothing was wrong with it....part is cheap if you can't do it yourself..labor may be $$$
2005 Grand Prix GT
3800
1995 Chevy Caprice
LT1 5.7
1986 Dodge Ram
