Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 11-20-2003, 09:51 PM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
passenger climate control
does anyones passenger climate control actually work, I can't feel a difference. so i dont know if there is an on or off switch or what.
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 11-20-2003, 11:29 PM
Indy8's Avatar
Indy8 Indy8 is offline
Re: passenger climate control
Mine works.
Quality isn't expensive, it's priceless.
Old 11-21-2003, 05:28 PM
dafrazi dafrazi is offline
Mine works. It's most noticeable in the heat of the summertime. You can actually feel a drop in air flow out of the passenger side vents.
Old 11-21-2003, 06:36 PM
thumpin455 thumpin455 is offline
Mine no work (1995)
Paul
Old 11-21-2003, 07:48 PM
oh yeah that answers my question.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 11-21-2003, 08:48 PM
dsatt12 dsatt12 is offline
Mine seems to work on my '95, but it's not a huge difference.
Old 11-23-2003, 04:11 PM
jim56's Avatar
jim56 jim56 is offline
on my 97 it seems to make a noticeable difference.... wife always keeps
it turned to the warm side during the summer, beacuse she doesnt like it as cool as me... i usually have it set on 75 most all the time.
Old 11-23-2003, 10:40 PM
is there an on/off switch for it?
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 11-23-2003, 10:46 PM
Indy8's Avatar
The middle(neutral)setting of the knob would be considered off.
Old 01-06-2004, 07:10 PM
bustedratchet bustedratchet is offline
Re: Re: passenger climate control
I found out mine works real good ! It's 15 degrees here and the Wife and I were driving to my Sons basketball game. First she says she is hot and cracks her window! Then she starts knocking the temp down on the dash 70,69,68........60 while my feet are about freezing and I'm wondering WTF???? Then a light bulb went off in my head and I glanced at the temp control knob on the door and it was full blast hot ! My Son put it there while taking him to practice at 6:00 every morning during the Christmas break. After I told her turn the knob down she said feel my feet I grabbed her ankle and it was cooking and my feet are on the other side freezing !
Old 01-06-2004, 07:39 PM
jim56's Avatar
Pas temp
Mine is acting up all of a sudden. Yesterday, it was blowing hot on the passenger side no matter where i set the pas temp control.climate control was set at 75.. just seemed to go from hot to hotter...
the other vents were blowing cool since it was pretty warm here..
today it seemed just the opposite, pas side was blowing much cooler that the rest..... I wonder if it is the switch, or the HVAC programmer that I hear is so bad to go out?
Old 01-06-2004, 08:31 PM
Keith1 Keith1 is offline
The programmer operates the driver and passenger air mix valves independently. If the passenger operates the passenger temperature control knob to request a warmer or cooler temperature on that side of the vehicle, the programmer operates the passenger air mix valve actuator to increase or decrease passenger side discharge temperature.
Old 01-06-2004, 08:53 PM
jim56's Avatar
so which is more likely to be the problem?
Old 01-07-2004, 08:16 AM
Re: Re: Re: passenger climate control
Could be anything Jim, switch, door wire, passenger side actuator, solar sensor ,or the programmer maybe you can drop the glove compartment and see if the actuator is moving.
Old 01-07-2004, 10:59 AM
jim56's Avatar
Re: Re: Re: Re: passenger climate control
I probably didnt describe what it is doing very well.. bear with me, I am fighting the flu..Ive never been this sick that I can remember.
I think the actuator is working to some degree, since moving the pas temp control does vary the temp of the air on the pas side.Its just not right.
The first time it was sunny and about 70 out. Climate control set at 75
The air from the other vents was cool, about what i would expect, but the air on the pas side was hot, adjusting the pas temp control was changing the temp, but was still much hotter even in the full cool position. In the second case, it was just the opposite. It was cold out,
and the system, set at at 75 again, was heating the drivers side just right, but was blowing cold on the pas side. Adjusting the pas temp control would warm it up a bit but was still a lot colder that the other side.
