Old 11-20-2003, 08:28 PM
u c p u c p is offline
Exhaust system vs. Exhaust tip
I'm not a big racer/performance driver, but I have decided to give in and turn my Civic into a "rice burner" by making it loud for no apparent reason.
I don't know TOO MUCH about what I'm doing, but I've got a small idea. If I simply bought an exhaust tip, would that alone change the sound of my car or do I need an entirely new exhaust system?
If exhaust system is the answer, forget it.
But if a simple tip will change the sound, I'm looking for recommendations. I don't want a tip so loud that I can be heard a mile away. But I don't want a tip that doesn't do a damn thing to the sound of my car. Maybe one that is, on a scale from 1-10 based on volume, about a 5. Any suggestions?
Old 11-20-2003, 09:04 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Exhaust system vs. Exhaust tip
Without removing or changing the muffler you will hear no difference in the sound of your exhaust system.
Old 11-20-2003, 10:47 PM
Then what exactly are exhaust tips for? Just looks?
Old 11-21-2003, 03:06 AM
JohnnyWash1's Avatar
JohnnyWash1 JohnnyWash1 is offline
Just looks. Think about it for awhile. How could a tip amplify sound?
2000 Mustang GT [email protected] Exhaust
2000 Celica GTS 6-speed A very pathetic 16.5@88mph (could not shift into 2nd or 3rd) Intake
1994 Integra LS I/H/E
1990 Integra RS 16.6@85mph Intake
Old 11-21-2003, 04:02 PM
454Casull 454Casull is offline
I'm not so sure. A lot of cars in my area have the OE mufflers and big tips and the sound level is fvcking annoying.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 11-21-2003, 05:23 PM
Are you kidding Casull? I've read your posts, and you seem pretty informed. I hope you are just messing with us...
Jon
Old 11-22-2003, 11:57 AM
pod pod is offline
you could cut out the resonator and the catalitic converter if you want that sound and replace them with pipe. you cant cut out the cat if you live in states where theres emmision controll, or you could just get a sport muffler and bolt in place, or even just clamp it
30 mpg in a brick on wheels isnt half bad...
Old 11-22-2003, 04:58 PM
Re: Re: Exhaust system vs. Exhaust tip
Jon
The following errors occured when this post was submitted:
The message you have entered is too short. Please lengthen your message to at least 3 characters.
Old 12-06-2003, 03:00 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
if you replace the muffiler with a sport one your car will be louder (a muffiler made for a larger diamiter exhaust system will be even louder) but there will be little performance gain
Old 12-06-2003, 07:31 PM
SaabJohan SaabJohan is offline
By chaning the tip the sound can be changed a bit. It will no be able to make your car to sound "sporty" it can however introduce annoying resonanses. This is due to the changes in length and that the silencing effect of the tips differ.
If you want to change the sound of the car I recommend that you replace the first muffler with a tube and the last one with a full flow/open type of muffler. For that I recommend that you use a tip with a silencing effect, especially if the engine is NA.
Old 12-07-2003, 09:37 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
You can buy tips at many shops here which alter the exhaust note, usualy in a very annoying way. I should imagine they are just as easily avliable in the US as they are here.
But there is zero performance gain.
Old 12-28-2003, 09:16 AM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
If you want to change the sound of your car, buy a REALLY big muffler, if there is a supressor inside, take it out. i saw a muffler on the web, called the bomb, claiming that if you removed the supressor inside you got a 5-10hp gain. muffler tips are mostly for looks but a small one can make put more restriction on your exaust system therefore slightly reducing performance.
Old 12-28-2003, 12:30 PM
The cheapest way to change the sound would be to cut off the muffler.
Old 01-01-2004, 12:44 PM
c a m a r o c a m a r o is offline
Banned
anyone ever tried these?http://cgi.ebay.com/ebaymotors/ws/eB...category=33633
Old 01-01-2004, 03:48 PM
cvcc_wagon's Avatar
Originally Posted by c a m a r o
nope but i would be lots of fun scaring the shit out of people in parking lots
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
