Old 11-20-2003, 06:17 PM
jon_mariani jon_mariani is offline
Send a message via Yahoo to jon_mariani
clip on window winder
where is the window winder clip? is it visible or in the door panel like that area? because if it is in side the dorr panel area its super hard 2 get 2 thanks.
Old 11-20-2003, 10:31 PM
wutangteo wutangteo is offline
Re: clip on window winder
i don't know if this clip is what you are talking about but when i took my side door interiors out to install new speakers, there was gold clip that held the interior. that is probably what you are talking about, if it is and you need more info, just ask ight
Old 11-20-2003, 10:38 PM
my fault, please ignore what i said before, you were talking about the clip that holds the window crank. anyways use a small screwdriver (or sometihng that fits in the hole of the crank, that'll get it out
also, search on google "remove window crank cavalier"
Old 11-24-2003, 06:43 PM
maximus1620 maximus1620 is offline
using a screw driver is a good way to get it out but is still a pain in the butt. there is a tool made for those clips but it doesnt work. it takes swearing and a scratched door. it takes a little bit, once you install a few speakers you will get a hang of getting those stupid things off.
Old 11-29-2003, 08:19 PM
sweetwhiteCAV sweetwhiteCAV is offline
Send a message via AIM to sweetwhiteCAV Send a message via Yahoo to sweetwhiteCAV
i hope im not too late
http://www.carstereohelp.com/stereor...ier2FDrSpk.htm
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 01:44 PM
window regulator daspyderman LS | MKZ 6 03-09-2009 03:07 PM
Window regulator troubleshoot anfrhm Sidekick 0 02-19-2009 12:40 AM
xj6 window winders charl du plessis XJ6| XJ8| XJ12 | XJR 0 05-21-2006 01:56 AM
how to get window winder off jon_mariani Cavalier 2 11-20-2003 06:04 AM
