1993 Cavalier axles
How do i pull the axles out on a 93 Cavalier?
Re: 1993 Cavalier axles
first you have to take your brake calipers off then your rotor, you have to also have a big deep well socket to get the axel nut off, if you have to ask anyone else for help say you need help removing your half shaft. i told you everything you need. i think the socket is a 32mm. but just buy a special axel socket.
You don't need to take the brake calipers off or the roter to get the drive shafts off. All you need to do is 1) remove the wheel. 2) remove the axle shaft nut with a deep socket I think it may be 32mm 3) remove the (balljoint) nut under the shaft. Note replace the cotter pin. Then pop off the ball joint use prybar to lower control arm down. 4) then use a pry bar to pry the shaft form the tranny and out she goes...
_________________ yhcet mg lacol ruoy |
thanks guys
i ended up taking off the ball joint then cut the clamp that holds the boot on then pulling the axles out at the joint, i tried to prying them out of the tranny but they wouldn't budge. thanks again for the info |
