Old 11-20-2003, 10:52 AM
Amish_kid's Avatar
Amish_kid Amish_kid is offline
91 Si Hatch
I'm looking to buy one atm and I'm wondering if there is anything I should look out for on the car itself I means the body is decent and it only has a little over 200km anything problematic with these models?
thanks
Old 11-20-2003, 12:13 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Re: 91 Si Hatch
thanks
Mainly just the typical stuff with these cars since they are 11-14 years old. Rust, particularly at the rear-wheels.
Depending on the condition of the car, you may end up having to replace a few suspension components, but nothing too serious.
Old 11-20-2003, 12:26 PM
Amish_kid's Avatar
Thanks and another thing, what just like the average you'd have to pay for front end parts and brake parts - labor.( I get it fo' Free! )
Old 11-20-2003, 12:27 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: Re: 91 Si Hatch
try and find one that hasn't been lowered and you'll have less suspension to replace . my current si is the only hatch i ever bought (to keep) pre-lowered. i must have bumped my head. as soon as the lowering springs came out and the coilovers & camber kits in (to go lower ) the suspension started to wear. the struts were toast within weeks.
a good rule of thumb i follow when buying a car is.....if it looks like a race car, chances are it was hammered like a race car. i like to buy unmolested grocery getters.....then molest them
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 11-20-2003, 12:38 PM
ci5ic's Avatar
Re: Re: Re: 91 Si Hatch
Ami likes deflowering civic virgins.
Old 11-20-2003, 12:46 PM
Amish_kid's Avatar
Yeah it's not lowered nor does it look like it's been "molested" just has a bra on it and I the current owner is probably in his 70's and the rust that would be on the car isn't bad just a wee little bubble on the passenger side rear quarter, which can be fixed with some sand paper and a little bit of primer and paint.
****** And another thing is it hard to drive if your tall I mean I'm over 6' would that be considered a bad thing with a car like this?******
Old 11-20-2003, 01:09 PM
outofstep's Avatar
outofstep outofstep is offline
Send a message via AIM to outofstep
Re: 91 Si Hatch
im 5' 10'' and i love my hatch so i dont think being tall is a problem, and my hatch is like 2 inches off the ground too hehe
90 civic:
JDM d15b
CAI
hp racing headers 4:2:1
custom 2 1/4 exhaust no cat
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
tockico illumnia 5ways
eibach sportline
front & rear strut bars
CF SIR hood
Check out outofgames.net for your gaming needs!
Old 11-20-2003, 01:15 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: 91 Si Hatch
I'm 6'4" and I don't have a problem with my hatch.
Check out my car here My 91 Hatch
Old 11-20-2003, 03:53 PM
Amish_kid's Avatar
And another thing I kinda forgot to ask and can't really seem to find a straight answer what are the specs for it?
Old 11-21-2003, 11:41 AM
amy@af's Avatar
Re: 91 Si Hatch
1590cc
4 cyl, 16valve
SOHC
9.1:1 compression ratio
Power: 108 bhp @ 6000
Redline: 7100 rpm
Torque: 100 lb-ft @ 5000
Old 11-21-2003, 12:44 PM
91HBSi 91HBSi is offline
Send a message via ICQ to 91HBSi Send a message via AIM to 91HBSi Send a message via Yahoo to 91HBSi
Like someone else said, it should just be the usual stuff. If I were you, I would check things like...
-Underneath the engine bay to see if there are any oil leaks
-The rust thing
-Drive it until the engine warms up nicely to see if things like grinds in the tranny occur (syncros)
-Make sure the a/c blows cold
-Any bad knocking (may be a rod). Normal valve chatter is nothing to worry about.
-Make sure the check engine light is not coming on, if so ask owner what the problem is. There is also a light under the passenger side carpet that will trow off a sequence of flashes indicating a particular problem. You can probably call a honda dealer to see what the code means.
That should be about it.
Lexus SC300 (Kazera KZa 18"x8.5" 245/40 (front), 18"x9.5" 275/35 (rear)... put on hold.
Civic Hatchback Si (I/H/E, d16z6 head, H&R springs/tokico blues, etc.)
94 Prelude Si (Sold!)
Former PureHonda.com member since Dec. 00
"For to me, to live is Christ and to die is gain." Pilippians ONe21
Old 11-21-2003, 06:03 PM
darolh darolh is offline
I have 165k+ miles on mine and all I've had to do is replace the alternator, main relay, brakes, headlight/turn sig switch, and timing belt. I have owned the car since 56k miles.
They're great cars. My original shocks are still good!!!!
Old 11-21-2003, 07:11 PM
Amish_kid's Avatar
Re: 91 Si Hatch
-The rust thing
Thanks will do and ha A/c is for wussies and just steals power from the motor even if it works its coming off the car if I get it. Whatever rust I did see was very minimal and on the surface so all that means is that I break out the sanding disc on the angle grinder, prime it and paint the spots
Old 11-24-2003, 10:24 AM
If being a man requires riding around all summer with a sweaty butt, then I'd rather be a wuss. If this was my secondary car, then I would tear the a/c out, but until it is... I'm keeping mine
92 civic hatch exhaust on 91 civic hatch yungtuner '88 - '91 Civic | CRX | Wagon | Shuttlee 1 05-05-2004 09:02 PM
Awww sh*t! Got my hatch back....MPFI working!.....spanked another hatch!...MUST READ bambam89lx '88 - '91 Civic | CRX | Wagon | Shuttlee 14 02-19-2004 06:06 AM
91 Hatch rear seats in an 88 hatch DJ_Inevitable '88 - '91 Civic | CRX | Wagon | Shuttlee 1 02-24-2003 10:55 PM
VX hatch vs CX hatch, differences?? Melt '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 09-17-2002 11:21 AM
Styling: New Civic Hatch VS New Corolla Hatch Oz Asia/Pacific 62 03-17-2002 03:48 AM
