| Performance Discussion about performance modifications and issues. |
Shift Indicator
Has any ever seen 1 of these in action?
How good r they? Formerly sold as the Hyperform Shift Indicator. It has the following great features: Quick and Easy Connection. - Just plug into the car cigarette lighter socket and the unit is ready to run. No wiring or soldering required. - Both electric power and RPM reading are sourced through the 12V cigarette lighter socket. Works with both manual and automatic transmissions. Easy setup with RPM range for optimum shift points. - User can preset the desired rpm range for the lights to come on sequentially or at the same time for optimum shift points. Brightness can also be adjusted as desired. Light Unit can be mounted in easy to see position without blocking the view. Backlit main unit can be hidden inside of glove box and still provides accessible adjustment. Main Unit Dimension: 8.8cm x 6.4cm x 2.4cm Light Unit Dimension: 5.6cm x 3.1cm x 1.4cm (excluding mounting bracket) |
