Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 11-20-2003, 02:00 AM
AfriKan AfriKan is offline
What do u do to help save on gas.... Fuel econamy for 90-94 maximas
Newbie here...
got a 1990 Maxima.... autom
just tryin to pick up on things....
anyways..
do yall drive on "comfort".... even on freeways.... unless u gota get somewhere quick or just racin....
switch between Overdrive on/off depending on situation.... ( i have to cause the RPM will go crazy when i reach 50+ on overdrive "on" )
i dont' know too much about cars........but "simple/common tips" are very much welcome...... cause the GAS is KIllin me........
Old 11-20-2003, 11:33 AM
SkyTorch's Avatar
SkyTorch SkyTorch is offline
Re: What do u do to help save on gas.... Fuel econamy for 90-94 maximas
Originally Posted by AfriKan
Newbie here...
anyways..
On my 91, I used engage OD at 45mph. I don't what mileage you are getting, but originally it was 19/26. Compare to a same year Corolla (28/33), that's not so good. But try to pack 4 of your friends in a Corolla. Unlike a Corolla, you have room and power. That's the trade-off. So if you launch at every stop light, your gas mileage is going to drop. You drive like grandma, you gas mileage will stay up. Your foot has more to do with mileage than any of those switches. If you already drive like grandma (yeah, right) than the next thing is strict maintenance. Strong as the car is, 13 years old in car years is usually past retirement age. Burn good gas, regular/frequent oil changes, and new spark plugs especially if your don't how long the current plugs have been in there.
Old 11-20-2003, 12:27 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
don't forget to run a fuel system/injector treatment
there's not much you can do with an auto to save gas. try not to nail the gas so often.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 11-20-2003, 02:13 PM
SkyTorch's Avatar
Re: Re: What do u do to help save on gas.... Fuel econamy for 90-94 maximas
Yeah, that fuel treatment is good stuff. If your car is losing power or just not running right, that stuff will fix a whole world of problems. Cheaper than a mechanic, too!
Old 11-20-2003, 04:32 PM
Caracicatriz's Avatar
Caracicatriz Caracicatriz is offline
What is a fuel system/injector treatment?
Old 11-21-2003, 10:48 AM
BP2K2Max's Avatar
it's a gasoline additive. go buy a fuel system treatment at autozone. i prefer the one called hit hard.
when you're ready to fill your tank with gas, go to the gas station(which probably has injector cleaner) and pour it in your tank then totally fill up. it mixes with the gas and as it passes through the gas lines and injetors and piston cylinders and all that, it cleans all the gunk out. they usually have an octane booster in them too for a lil extra oomph. i run one through my car every 10K miles or so
BP's Rides;
Old 11-21-2003, 02:39 PM
SkyTorch's Avatar
Re: Re: Re: What do u do to help save on gas.... Fuel econamy for 90-94 maximas
They cost anywhere from $1.99 - $3.50 a bottle usually. There are a few different ones made by STP, Berryman, Gunk et al.
Old 11-23-2003, 11:37 PM
jmd102 jmd102 is offline
A common overlooked item is the O2 sensor(s). I've seen many not up to snuff and not set a code ,but give you crap mileage. Best way is to tie into the return wire from the O2 and measure the voltage while engine is warmed up. Should cycle between .1-.9 volts DC.
Anything below .7 it's toast! I've seen many do the .7V thing and not set a code, but it will affect emissions and mileage even though the car may seem to run OK. I do emissions repairs and diagnostics and this is a pretty common item to eat up your wallet slowly. Easy to check, just need a DVOM. Digital volt meter. Have fun!!
