Old 11-19-2003, 11:05 PM
mattbrye mattbrye is offline
Clutchity clutch clutch
I got a 99 LS teggy and i plan on getting my turbo in bout a yr or 18 mths. I know i need a new clutch and flywheel 1st. My question is if i put the ACT clutch in now..would it be to worn down and not good enough by the time i get a turbo about a yr and half down the road??
Old 11-20-2003, 01:13 AM
Milliardo's Avatar
Milliardo Milliardo is offline
Send a message via AIM to Milliardo Send a message via Yahoo to Milliardo
Lightbulb
Here's my suggestion: go buy all the things you need, store them, and when you have the turbo have them installed all at one time so you'll save up both on time and money. That would work better than buy them now, put them, and find out the clutch is worn down a year later to have it replaced.
Admin of PGamers Forum
1993 Honda Civic ESi (Sailor Mars)
My wish list--I need help in this project: http://pikarod.fateback.com/car3.html
Old 11-20-2003, 01:39 AM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: Clutchity clutch clutch
I'd say that if you wear out an ACT clutch in 1yr then you need to learn how to drive a stick before you even think about going turbo with your car.
Check out my car here My 91 Hatch
Old 11-20-2003, 09:35 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: Re: Clutchity clutch clutch
tru
I had an act on my DX engine and it gripped like a mofo for about a month, then just felt a little clampier than stock after it broke in, but never slid for the 6 months I had it (It slid on the 300 shot of nitrous I accidentally used, and blew the motor, but that's a different story ). Like said above just install them all at once instead of replacing something that already works fine for what you got.
Old 11-20-2003, 04:13 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
don't replace your clutch right now unless you really need to.
"If it ain't broken, don't fix it."
