| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
jdm itr
what exactly is a jdm itr motor?
what is the base engine that they start with? what head ,cam(S)? i hear all this talk about it but have never seen any spec's
82 civic wagon amsoil high flow air filter apex'i muffler future motor swap ride [email protected]![]() Member of TeaM NiGLeT iNC. MeMBeR NiGLeT eLiTe GuaRD more bodyroll than a 500 Lb G.A.W.A. ?WHAT YOU LIKE TO DO WITH PUNANNI? POONSAI! |
A JDM ITR motor is a motor from a Japanese Integra Type-R.
Called a B18C Spec-R 11.1:1 compression, slightly more aggressive cams than the US version, 4-1 headers straight from factory, and etc. Much more desirable than the US version - but the US version can be made to be exactly like a JDM one. (except the B18C5 block stamp, but o well) The head is the same as the US, mildly ported an polished B16A-type head. 200-205hp at the flywheel vs. the US 195. hope i helped
"Son, your eyes look a little red there. You've been hittin the Vtec haven't you? Alright, stand on one foot, touch your nose and say 'Third Rocker Arm'". Original PH Member (Reppin' for original PH'ers!) www.lunspeed.com www.jdmcivic.com www.sweetcarz.com ![]() |
vtec boi put it all in a nutshell, i think it is 205 at the flywheel
even though its only ten ponies every bit helps imo
often imitated but never duplicated |
Re: jdm itr
in 95-97 the B18C3 was the ITR motor and made 195 to the crank. in 98-01 the B18C5 was itroduced and it made 204.7 hp, but was rounded up to 205. what Honda of Japan doesn't want you to know is that it is governed at 200kph and has a acceleration govener to when the peddle is floored, you are only receving 9/10 throttle due to fuel lack. with the ECU fixed and ungoverned, you can make about 220 hp on this motor and top out aroun 240km at 10,000 rpms
Your V-8 can't touch this sweet Honda Integra XSi..... |
Re: jdm itr
it is a GS-R block with CTR pistons, a B16A head, w/ CTR camshafts, and CTR valves, and CTR valvesprings
Re: Re: jdm itr
