Gen3 iridium vs. Bosch Platinum +4 plugs
Has anyone put these to the test?
I use th Bosch +4's in my other vehicles (V6 & V8) but I have no exp. with the iridiums. I have a 90 Si and I planed on only adding bolt-ons (ie.,header,intake,plugs,wires) If you have exp. the question is Denso or NGK.... Thanks Last edited by laidback22; 11-19-2003 at 02:52 PM. |
Doesn´t matter! Both (Denso and NGK plugs) are well for our Hondas!!
Re: iridium vs. Bosch Platinum +4 plugs
I have bosch plat +4s...I was ignorant when I bought them for 6 dollars (I believe) each!! To tell you the honest to god truth, the design of the plugs are just a marketing scheme. The 4 tips doesn't allow better spark or better ignition, it's just a design. Just get some NGK plugs, they are better.
Ngk plugs are factory fit on many imports
spark plugs are all the same, wires are what makes the difference
Re: Re: iridium vs. Bosch Platinum +4 plugs
actually, not all spark plugs are the same....Put a pair of autolites in your honda and come tell me there isn't a difference. Wires with lower resistance per foot allow more voltage to reach the plug. This produces a more powerful spark for a more complete burn. The Bosch platinum4's are a marketing scheme; in a way. Electricity always takes the path of least resistance, therefore, the spark will only travel to one electrode (the one with least resistance). This does allow for a better spark because it can find the easist path each time, but its not worth the difference in price. Let bosch stick with the german cars, Ngk with the Asains, and autolite with domestics.
94' Del Sol VTEC (B16A3) SOLD. Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles. |
with a stock H22A ignition system. http://asia.vtec.net/beystock/hybrid/art2/ (Thanx to drift for the info and link!) Stock ignition system is already well designed.... |
I haven't played with the iridium plugs yet, but I trust NGK in general, so they'd be my first choice. As the others have said, the Bosch +4 plugs are 100% gimmick. There may be one theoretical advantage: if the best electrode (the path of least resistance) wears down or becomes sooty, then the current will just find its way over to another plug. In practice, the plug will probably be near the end of its useful life before this happens anyway, and most of the usual things that foul plugs should foul all four electrodes at the same time. In any case, they're not worth the ridiculous price.
Anybody feel free to correct me if I said something that just doesn't make sense.
"There are no substitutions for revolutions."
Member of AF's Slide Squad (Member #05) |
Privatebigandrew is right. unless you have a high power ignition system or some nology hotwires, the spark rarely, and i mean RARELY meaning almost never, reaches more than one prong on the tip of the plug. if you are lucky it MIGHT spark on two of them, but then again, if its only sparking on two, whats the point of four? gimmick. i have denso iridiums. great plug.
Thanks for the replies
I am going to do a tune up on this car as I just bought it and have no idea how old the current components are. I think I'll go with the irridium plugs, new wires, air filter for now until i figure which intake to put on. |
good idea
MGK IX stick with these for hondas
i dunno about denso, asking a litlle too much, seems to be the same plug to me IMO |
Re: Re: Re: iridium vs. Bosch Platinum +4 plugs
