Old 11-19-2003, 10:10 AM
Phill Acio Phill Acio is offline
A common 3.4 GTP Problem that seems to lack an answer
Ok I have a 94 GTP with a 3.4. Im having problems with it idling. My car seems to enjoy idling at 2000 rpms for some reason. It doesn't do it all the time. It really has a hard time ilding when it first starts in the morning. It will jump up to 2000 then down to 500. It will either die or ilde back up. It will search for an idle then eventually run normal for alittle bit. While im driving it will either idle high or run normal and every once and a while the SES will come on, but only for a little bit. When it is idling high it is running real ritch. I can smell the gas comming out of the exhaust. Any information would be greatly appriciated.
Old 11-19-2003, 01:32 PM
rockford0384's Avatar
rockford0384 rockford0384 is offline
Re: A common 3.4 GTP Problem that seems to lack an answer
sounds messed up. I once had that same engine in my old GTP and It would idle high like that when it first starts up and sometimes it wouldnt even want to start. I dont know if this would help out any ... but change the fuel filter... That seemed to be the best thing i ever have done to that car to make it run good. It had 157000 miles on it when i sold it. It finally died though at 178000 miles! Thats crazy for that engine. anyways im not sure really whats you problem. sorry
Old 11-20-2003, 09:30 AM
RABarrett RABarrett is offline
Several things come to mind here. There is the possibility of a vacuum leak. There is also the possibility of the need for a thorough throttle body and IAC cleaning. I would check for vacuum leaks first. Ray
Old 11-20-2003, 11:19 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Those engines are known for developing vacum leaks at the PCV hose and the intake manifold.
I would check those places first.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-21-2003, 10:28 AM
winaukee winaukee is offline
Thumbs up Re: A common 3.4 GTP Problem that seems to lack an answer
Lucky for you i have the answer to your problem. I had the exact same problem until i replaced my upper and lower intakd gaskets. That will take care of it for sure!!!!! cost about 350$
Old 12-04-2003, 09:32 AM
BLOWN_GTP's Avatar
BLOWN_GTP BLOWN_GTP is offline
Send a message via AIM to BLOWN_GTP Send a message via Yahoo to BLOWN_GTP
your problem is the intake gaskets. Turn your car on and pull the 3.4 plastic cover off and spray some TB cleaner around the intake. That is a cheap way to diagnose the problem right there because if there is a leak when the spray is applied your rpms will fluctuate. Upper and lower intake gaskets are an easy job. Dont let the 3.4 motor scare you because of the size. Unfortunately it scares most people into selling it.
2000 Silvermist GTP
"Lightly Modded"
MSP intake / 3.4" pulley / GPS PCM / 12" brakes / Lotek 3 gauge pillar pod / Autometer Gauges / Yellow Top battery / Koni struts+springs / 34mm front sway / 19mm rear sway / poly bushings / Sylvania Silverstar lights / Blazertech 3200's / Goodyear Gatorbacks and too much more to list!
http://conncgp.net/gallery/Mark
Old 12-09-2003, 12:11 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
I agree, check for vacum leaks and also clean the intake trhotle and IAC hole clean of the black dust.
Old 02-09-2004, 08:14 PM
twstice twstice is offline
Send a message via AIM to twstice Send a message via Yahoo to twstice
Im having the same problem, and still havent come up with an answer
im new here, and ive got the exact same problem with my '95 grand prix gtp 3.4L DOHC. i replaced the throttle position sensor thinking it might be that, it didnt change.(i read in another post that i might have positioned the sensor wrong, so that might still be the problem). i also tried replacing the idle air valve sensor, b/c sometimes when i unplugged it the engine would idle like it's supposed to for a while..., i replaced the idle air valve and it did not change with 3 different valves. i recently tried replacing the intake gaskets, but i only replaced the upper gasket. it still did not change how the engine runs. should i maybe go ahead and replace the lower intake gaskets as well??? or what should i do??? i will have looked all over the place for a vacuum leak and as far as i can tell there isnt one, i might have over looked one though. PLEAS HELP, i cannot seem to figure this out.
thanks ahead of time,
-Trevor
P.S.( i just noticed this is a rather old thread, i hope someone notices this)
Old 02-09-2004, 09:52 PM
JGTP94 JGTP94 is offline
Send a message via AIM to JGTP94
I had the same problem in my 94 GTP and Believe it or not INTAKE gaskets... A very common problem in these engines i hear just not one thought of much. mine did exactly what u discribed and once it was fixed it now runs perfect no idle probs
hope this helps...
-Jason-
Old 02-09-2004, 09:56 PM
ok, i will go ahead and replace the lower intake gaskets as well. i hope it works, thanks.
-Trevor
Old 02-23-2004, 12:58 PM
dopey273 dopey273 is offline
My gtp did the same thing.. pull the engine codes. mine came up with the o2 sensor. what would happen is it would be erratic sometimes runs fine sometimes not, you could smell the gas. the ses light would come on intermittently also. What was happening was the o2 wasn't registering properly, it would read lean then the ecm would try to fix it by adding more fuel, when it did that , then it read rich. I replaced the o2 sensor, which i had to remove the top plenum to do it, and it fixed the problem, I even got better performance and fuel mileage... I would suggest getting the engine codes pulled first before doing anything though....
Old 02-24-2004, 08:36 AM
slacker_53's Avatar
slacker_53 slacker_53 is offline
As stated in a previous post, spray some WD-40 around the intake while the engine is running. The idle should change a little if you have an intake leak, when the engine picks up the WD.
Cheap and easy, just like my girlfriend.
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 09-28-2005, 12:11 PM
JDLB JDLB is offline
I have the 3.4 DOHC in a '92 Cutlass Supreme that has the same problem. I already changed the IAC and upper intake gasket, but it still runs at 1500-2000 RPM's when i start it, and then it will sit there and pulse the RPM's when in drive or reverse. I can't figure out the problem.
Old 12-07-2005, 11:10 AM
MoDoggie MoDoggie is offline
Angry Re: A common 3.4 GTP Problem that seems to lack an answer
I have the 3.4 DOHC in a 94 Grand Prix GTP and when I bought it it had a serious idling problem. I changed the intake gaskets and that fixed it. Then I just recently tore it down to the block to fix an oil leak at the oil pump drive shaft (distributor). Now that I have it all back together I am having problems with it staying running. I will start but idles very rough not erratic like before and once it warms up it will stall out when idling whether in gear or not. I have checked for vacuum leaks and have found none, not sure if it is a sensor but the SES light did come on once, but has since went back off. Any other ideas???
