Old 11-19-2003, 01:58 AM
aces1980 aces1980 is offline
apexi vafc?
Does anybody have a how to on this? i have a friend that just did the minime swap in the his hatch and wants to know how to conect his vafc. He has a D16y8 head on a D16a6 block. We checked the website and we are still not sure on how to do it cause he is using a pm6 ecu which has no vtec signal wire. Also we were trying to find out which wire was what. Has anybody done this before that can give us a hand. we would really apreciate it. thanks in advance.
Old 11-19-2003, 02:09 AM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
Re: apexi vafc?
yeah...the wiring diagram is correct if i remember correctly, just don't hook up the VTEC input wire.
Check with a service manual before cutting, just in case the A'pex-I manual is wrong.
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 11-19-2003, 02:18 AM
so follow it exactly and not worry about that wire? What about the VTM Signal? what is that? Does anybody know where i can get a wiring diagram for the pm6 ecu? thanks
Old 11-19-2003, 02:42 AM
Re: apexi vafc?
I left my notes at home, but yeah, wire it up exactly, If they don't show a wire being hooked up, don't hook it up. The pinouts should all be the same.
16mb version of the factory manual, I think the wiring is in Here under the 4G section, get the manual.
i wish it was fast
here is my website
Old 03-24-2007, 03:32 AM
DHHTR DHHTR is offline
Send a message via MSN to DHHTR
Smile Re: apexi vafc?
hey brothers,
do any 1 of u know where to get the tuning instruction manuel of VAFC 1...???
bcause i'm tryin to do my own tuning on my EK4
thanks
Old 03-24-2007, 04:27 PM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
Re: apexi vafc?
this is all you need. a basic obd-0 ecu pinout and the color code for the vafc wire harness.
Wiring Colors and Functions
DPFI MPFI
Pin # Wire Color Function Wire Color Function
A1 Yellow 2 Aux Injector Brown #1 Injector
A2 Black 1 Main Relay/Ground Black 1 Main Relay/Ground
A3 Yellow 1 Aux Injector Red #2 Injector
A4 Black 2 Main Relay/Ground Black 2 Main Relay/Ground
A5 Red 2 Main Injector Light Blue #3 Injector
A6 Green Purge Cut Off Solenoid Valve (Coil) Green Purge Cut Off Solenoid Valve (Coil)
A7 Red 1 Main Injector Yellow 1 #4 Injector
A8 Yellow 3 Sedan LX A/T
A10 Red EGR Solenoid Control Valve (Coil) (A/T only)
A11 Blue/Yellow EACV (Coil) Blue/Yellow EACV (Coil)
A12 Green/Black 2 Main Relay Green/Black 2 Main Relay
A13 Yellow/Black 2 Main Relay Yellow/Black 2 Main Relay/Injector Resistor Box
A14 Green/Black 1 Main Relay Green/Black 1 Main Relay
A15 Yellow/Black 1 Main Relay Yellow/Black 1 Main Relay/Injector Resistor Box
A16 Brown/Black Ground Brown/Black Ground
A17
A18 Black/Red Ground Black/Red Ground
DPFI MPFI
B1 White/Green Hazard Fuse White/Green Hazard Fuse
B2 Orange Tandem Control Solenoid Valve Blue 1 Fast Idle Control Solenoid Valve
B3 Yellow A/C Clutch Relay Yellow A/C Clutch Relay
B4 Yellow/Green Radiator Fan Relay Yellow/Green Radiator Fan Relay
B5 White/Yellow Alternator White/Yellow Alternator
B6 Green/Orange Check Engine Warning Light Green/Orange Check Engine Warning Light
B7 Green/Orange A/T Shift Position Console Switch (Park, Neutral)
B8 Blue/Red A/C Switch Blue/Red A/C Switch
B9
B10 Orange Crank Angle Sensor
B11 Green/Black A/T Shift Position Console Switch (Drive)
B12 White Crank Angle Sensor
B13 Blue White Main Relay Blue White Main Relay
B14 Blue 2 To Yellow, To Alternator Blue 2 Alternator
B15 White 1 Ignitor Unit White 1 Ignitor Unit
B16 Yellow/Red Speed Sensor Yellow/Red Speed Sensor
B17 White 2 Ignitor Unit White 2 Ignitor Unit
B18
B19 Green/Red Electric Load Detector Green/Red Electric Load Detector
B20 Brown Ignition Timing Adjusting Connector Brown Ignition Timing Adjusting Connector
DPFI MPFI
C1 Orange Crank Angle Sensor Blue/Green Cylinder Position Sensor
C2 White 4 Crank Angle Sensor Blue/Yellow Cylinder Position Sensor
C3 Orange/Blue TDC Sensor Orange/Blue TDC Sensor
C4 White/Blue TDC Sensor White/Blue TDC Sensor
C5 Red/Yellow TA Sensor Red/Yellow TA Sensor
C6 Red/White 1 TW Sensor Red/White 1 TW Sensor
C7 Red/Blue Throttle (Position) Angle Sensor (TPS) Red/Blue Throttle (Position) Angle Sensor (TPS)
C8 Yellow EGR Lift Valve Sensor
C9 Red/White 2 PA Sensor Red/White 2 PA Sensor
C10 Green/White 3 Brake Switch Green/White 3 Brake Switch
C11 White 1 MAP Sensor White 1 MAP Sensor
C12 Green/White 2 EGR Lift Valve Sensor/Pa Sensor/Ignition Timing Adjusting Connector/TA Sensor/TPS Sensor/TW Sensor Green White 2 Pa Sensor/Ignition Timing Adjusting Connector/TA Sensor/TPS Sensor/TW Sensor
C13 Yellow/White EGR Lift Valve Sensor/Pa Sensor/TPS Sensor Yellow/White Pa Sensor/TPS Sensor
C14 Green/White 1 MAP Sensor Green/White 1 MAP Sensor
C15 Yellow/Red MAP Sensor Yellow/Red MAP Sensor
C16 White 3 O2 Sensor White 3 O2 Sensor
ok now off the top of my head heres what i can remember about the vafc harness
pink is vtec selinoid
yellow and white are used for the map sensor. not needed if you just want to use vtec settings. only used to correct fuel
brown and black are grounds, put them to any ground wire off the a pin at the ecu
orange and red are power wires. put them both to the 12v sorce on the a plug at the ecu
grey is throttle position sensor
green is rpm signal
thats all i can think of off the top of my head. sorry. but im pretty sure this is all you need
APEXi VAFC nemesls_2000 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 02-08-2002 02:16 PM
APEXi VAFC wiring harness nemesls_2000 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 02-06-2002 10:13 AM
Apexi VAFC Veetec Europe 10 01-27-2002 11:21 AM
Tuning an Apexi VAFC adidas_man Engineering/ Technical 1 01-25-2002 10:14 AM
goe me a Apexi VAFC for 98 lude :) kenchan Prelude 2 09-26-2001 01:16 AM
