Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 11-18-2003, 10:06 PM
1NYCGUY 1NYCGUY is offline
Question 99 Explorer Sport Rough Starting
I have a 1999 2d 2wd Sport that has about 82000 miles on it's 4.0L 6 cylinder engine. Lately it seems that in the morning regardless of the weather conditions but mainly when it is damp out. the car doesn't want to start. It usually takes 10 or more minutes to get it to turn over.
Before I embark on a full fledged tune up I was hoping to get some advice from the forum folks.
Please advise,
Thank
Old 11-22-2003, 07:36 PM
bustedratchet bustedratchet is offline
Re: 99 Explorer Sport Rough Starting
Go for the tune up.If you take it somewhere and they recommend a throttle body cleaning do that too.
Old 03-29-2004, 09:13 AM
ralphrides ralphrides is offline
no start on humid days
I have had many vehicles and there are usually two issues to check.
Check for bad spark plug wires. Do ohm test on them and all should be close to same pending on length. Cracks in wires will short on damp days. Try drenching wires with WD40 spary oil. If starts ok wires are bad. Other is coil. if coil is shorting internally problem will be worse on humid rainy days due to weak spark. Clean the top of coil with WD40 spray too. Real dirty coil tops and old wires can short around coil towers. If coil is shorting inside, a typical other problem is high speed bogging and power loss. Need best spark on high speed high load.
Check some plugs for excessive buildup of deposits, could also make it harder to start on wet days, but do wire and coil checks first since poor spark can clog plugs as well.
Rough idle during cold weather start mobzs Sierra 1 03-26-2011 12:00 AM
running rough and getting bad smell from exhaust on 2000 ford explorer sport nitrowizard88 Explorer | Explorer Sport Trac 6 02-03-2011 09:56 PM
99 Caravan Sport Rough Idle and Stalling blase Caravan | Voyager 8 10-10-2010 07:48 PM
98 explorer, bad idle and rough start --MAP, MAF? PBFreeland Explorer | Explorer Sport Trac 15 02-09-2010 09:56 PM
94 Explorer sometimes won't start or idles rough kylegrand Explorer | Explorer Sport Trac 10 01-23-2009 11:59 AM
