Old 11-18-2003, 04:29 PM
blade34609's Avatar
blade34609 blade34609 is offline
92-95 Civic Manifold On 4th Gen?
Hi,
I will be doing my MPFI swap soon.
Is it possible to use a DX 92-95 intake manifold for the MPFI swap?
They look almost the same.
This is the one- http://cgi.ebay.com/ebaymotors/ws/eB...category=36474
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 11-18-2003, 04:41 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
ive heard of this working but have no confirmation about it, though i heard it was on an ex.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-18-2003, 06:11 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: 92-95 Civic Manifold On 4th Gen?
Yes you can since they are both a D series motor but you will still need the 88-91 ecu and injectors from a si/ex oh and the injector resistor box. or you can use the 92-95 ecu and injectors and wire for obd1.
Check out my car here My 91 Hatch
Old 11-18-2003, 08:12 PM
blade34609's Avatar
Re: Re: 92-95 Civic Manifold On 4th Gen?
Alright thats a relief because I know junkyards have tons of the 92-96 DX manifolds. So all the sensors, and throttle bodies work on the DX manifolds?
What do you mean injectors? The 4 fuel injectors will need to be replaced? I cant use the ones that come with it?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 11-18-2003, 08:18 PM
The injectors that come with the 92-95 are Obd1. You can use them but you need a 92-95 ecu.
Old 11-18-2003, 08:23 PM
blade34609's Avatar
I dont mean to sound too stupid. but so if i lets say get a 92-95 DX manifold and use the fuel injectors. I will also need a 92-95 ecu.
Does it just plug in the stock location of the 4th gen ECU?
After that can I just I just do the MPFI swap like it says?
ECU wiring and dizzy wirign will all be the same correct?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 11-18-2003, 08:30 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
88-91 si's have peak and hold injectors that require the resistor box, 92-95 civic have saturated injectors which require no resistor box
u can find 4 a6 injectors and resistor box and use them with your 92-95 manifold it wont make a diff altho when your done with the swap you might have acouple connections or plugs that couldent be used but it will still work
2002 Acura TL Type S
1991 Honda Crx Si
Old 11-18-2003, 09:18 PM
blade34609's Avatar
Alright thanks alot for the info.
How much do you think 4 fuel injectors will cost me? Lets say I got them at Autozone or Discount Auto?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 11-18-2003, 09:39 PM
88hondaowner 88hondaowner is offline
Banned
Send a message via MSN to 88hondaowner Send a message via Yahoo to 88hondaowner
Hey if your doing a MPFI swap your gonna need a PM6 ECU....Guess what today is your lucky day. I am selling one from a 89 5speed for 55bucks shipped!!
Old 11-18-2003, 10:44 PM
travagliante's Avatar
travagliante travagliante is offline
Just do the obd1 swap i posted earlier no response. I did it it was super easy kind of. All you do is get the manifold all sensors and ecu. i got this all from a junkyard(ecu, sensors, and manifold for only $40.00)......
Search for the obd 1 conversion harness.
Do that first.
Then you can follow the steps in the mpfi swap guide the # of pins are the same but the connector is different. Follow the instructions but dont use the injector resistor box. Its very cheap and a 5gen dx is better than a 4gen ex. Only when pertaining to the manifold.
I reccomend changing all gaskets and also giving it a good cleaning. .
Hope this helps
Old 11-18-2003, 11:52 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
I have 5th gen manifolds on both of my cars. The only real difference is that the map sensor is on the TB instead of the firewall, so you have to either use that map sensor and lengthen the stock wires, or else plug up the hole and use the stock map. otherwise, mine work perfectly.
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 11-19-2003, 10:06 AM
blade34609's Avatar
Alright thanks.
So just to clarify this.
I will need a complete 5th gen intake manifold with all the sensors and injectors. I will also need the ECU and complete wiring harness OBD1.
Will I still need the injector resistor box? If I convert to OBD1?
Is this a good OBD0 to OBD1 swap site?
http://www.knology.net/~jediklc/OBD0...BD1%20Swap.htm
Is it cheaper doing it this way or should I jsut do the regular MPFI swap?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 11-19-2003, 10:59 AM
No need for the resistor box with obd1. It is cheaber to go whichever way the junkyard will sell the stuff the cheapest.
Old 11-19-2003, 01:52 PM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
I am 99% sure you can use the OBD1 injectors w/ the OBD0 ECM (PM6) and just leave out the resistor box.
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 11-19-2003, 02:02 PM
blade34609's Avatar
I think i may just go with the 88-91 SI manifold because it seems like its alot easier. And cheaper by the time I got done with it.
Anyways thanks guys.
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
