Go Back   Automotive Forums Car Chat > Chrysler > General Discussion
Old 11-18-2003, 02:33 PM
hypermaxed hypermaxed is offline
Unhappy Turn Signal
I have a Problem with a 93 Lebaron 2 door coupe.
The Problem is my right turn signal works fine, when I go to use the left turn signal it won't work. First thing I did was check all the fuses. Second thing I did was check the flasher. it ain't a normal one that connects in the fuse panel. this one sits under the dash by the radio. its a four prawn connector. after I took all the fuses out the first time the left signal worked for about a day. I really hate to remove the dash plate again to get to the flasher/relay. the fuses look dirty under the dash and in the motor. cleaned them up but still no effect ....
please post any idea's
thanks
hypermaxed
Old 11-23-2003, 12:55 AM
Question Turn Signal Switch
I finally figured out the problem it's the switch itself the contacts on it are bent all to hell.
I made a site and put pictures of the one I need.
http://hypermaxed.tripod.com/ts_switch.htm
please check it out and email if you know where I can get just the switch
Thanks
Hypermaxed
Old 11-23-2003, 12:56 AM
I forgot to mention that I called all the salavage yards in my area. none of them have a 1993 lebaron ... or if they do the switch has already been taking from it..
Old 11-23-2003, 06:37 PM
Elrod on the V-Rod Elrod on the V-Rod is offline
Re: Turn Signal
Buy a new one!
Old 11-23-2003, 08:14 PM
Re: Turn Signal
They want $100 to $125 brand new and I just put all my money into buying the car
Corey
Old 11-25-2003, 02:25 AM
proticus's Avatar
proticus proticus is offline
Re: Turn Signal
sounds like it's time to call all of the salvage yards that aren't in your area. there is only one good salvage yard near me. and in good traffic, i can make it in about an hour and fifteen minutes.
