Old 11-18-2003, 01:57 AM
Notor1us Notor1us is offline
heat, ac switch
the blower wont do anything but flow to the floor and the ac wont kick on unless the switch is turned to the off position, im wondering if its the switch or maybe the blower actuator or maybe both? i have no idea.
Old 11-23-2003, 10:28 AM
philoldsmobile philoldsmobile is offline
Re: heat, ac switch
hmmm, Dads 96 Tahoe has just had the same fault develop. anyone have any idea?
what do you mean, its got enough power?
Old 01-24-2004, 04:33 PM
jcooley jcooley is offline
Re: Re: heat, ac switch
Same problem here. For a while, my a/c wouldn't stop blowing. Even if I cut it off it continued on low. Then it really started acting weird as only a few spots low, and high would work. Now they have all quit working, and I have no heat except the seats, lol. Any idea of what has gone bad. Thx in advance.
JCooley
Old 01-25-2004, 04:51 AM
Re: heat, ac switch
Dads is sorted now, turned out to be the HVAC pannel in the dash gone bad. once the new pannel arrived, it was a relatively easy instalation, as everything just clips into place, just a bit fiddly. two screwdrivers needed to depress the plastic tags that hold the HVAC pannel in.
Apparently it is a common problem
TIP: Smell When Run Heat on FULL... Intuit Escort 7 11-14-2009 04:11 AM
1994 voyager ac and heat problems bitco Caravan | Voyager 2 10-20-2009 08:49 AM
1989 - defroster/vent/heat switch not working ron h M Bodies 3 10-13-2006 08:53 PM
2000 Suburban Hot/Cold AC/Heat Switch dkraines Suburban 4 06-11-2006 09:27 PM
Rear heat switch, 99 Windstar jboler Windstar 0 01-16-2006 08:58 AM
