Old 11-18-2003, 02:09 AM
Sebstar's Avatar
Sebstar Sebstar is offline
Paint the chassis?
Sorry for all these noob questions but I just want to make the best out of the first model Anyway do you guys paint the undercarriage? I am asking this because my rx7 is going black, and since the plastic is black I thought I could just keep it that colour. Or, I could just cover it with a layer of the black spraypaint, but don't know if that is really worth it
ps: tomorrow i'm putting together the rear suspension and starting on the front, w00t.
Old 11-18-2003, 02:36 AM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
I normally just give it a dusting with spraypaint. Not too thick, though. You don't want to fill in the detail, but you want to cover up any visible imperfections in the plastic.
I work slowly!
Old 11-18-2003, 06:09 AM
MrHappy's Avatar
MrHappy MrHappy is offline
Send a message via Yahoo to MrHappy
Re: Paint the chassis?
Agreed..
If you do this you'll also get a nice semi gloss effect with a very slight Orange peal. For a change this is good!
Most cars now have a protective paint covering on the undercarriage to prevent rust and chip damage etc. Most of the time the effect looks like spay orange peel. Mazda MX5/Miata even have this effect on the lower part of the body paint. Have a close look the next time you see one.
Old 11-18-2003, 07:49 AM
Sebstar's Avatar
hm, i will do that mrhappy
hehe, alright so then I'm gonna prime the body tomorrow, and spray the undercarriage/engine bay. also, i just built a tip out of a couple of straws (like drinking ones). lets hope it holds up
and grr, i tried the wheel in the brake setup, and the glue mustnt have been dry or something, but i pulled it off again. arr... either way lets hope the priming goes good this time (2nd try)
wish me luck
Old 11-18-2003, 08:00 AM
SonyMobile's Avatar
SonyMobile SonyMobile is offline
Send a message via AIM to SonyMobile Send a message via Yahoo to SonyMobile
Yes, I always paint my chassis, I think the best part about my models is always the part you dont see and frankly it pisses me off. I do all my best painting/detailing on the underside of the car.
Old 11-18-2003, 03:22 PM
hypertek's Avatar
hypertek hypertek is offline
Umm Im going to try this. Just leave your fender weil black?
Old 11-18-2003, 05:20 PM
urraco75's Avatar
urraco75 urraco75 is offline
Personaly, i paint all the pieces of my kits. Chassis, interior, engines, suspensions, ... all pieces. I think it give the model a great aspect when it's finish. I always paint in mat black the internal faces of the body (sorry for my english )
If you paint all the suspensons, interior, ... when the pieces are on the grapps in mat black with an airbrush, you will get a very nice final aspect, try...
Old 11-18-2003, 10:49 PM
Sebstar's Avatar
i dont have an airbrush, thats why i was asking. if i had i would paint everything, because its much easier and looks better
Old 11-19-2003, 04:53 PM
primera man's Avatar
"P-Man"
Paint everything so that you know you have the done the best job possible
View All My Models Here.
Old 11-19-2003, 07:11 PM
gasman03's Avatar
gasman03 gasman03 is offline
well, i'm not 100% sure, but if Mazda does there painting like Ford, the underbody should be primer, with black overspray along the sides, but I recommend just lightly spraying it black over the kit plastic
Old 11-19-2003, 07:17 PM
blueboost's Avatar
blueboost blueboost is offline
Re: Re: Paint the chassis?
HEY! I like my half arse models thank you
j/k yes, you should paint the underside. people always want to look under there for some reason. so, always wear clean undie's and paint the underside of the chassis.
Old 11-19-2003, 10:57 PM
Jumpman_Z's Avatar
Jumpman_Z Jumpman_Z is offline
Send a message via AIM to Jumpman_Z
Yeah, I always paint the chassis. I like the way they look in Plastikote Pewter, or chrome, or flat black. If you use a high gloss color, make sure you prime it, because with all of those edges, you are likely to get paint run, even with thin coats. It has happened to me a couple of times, and it's a real PITA to remove the paint between the edges.
Air 23 - News, release dates, info, tons of pics, and much more!!
Air Jordans
Air Jordan release dates
Z33, 287 hp, 274 lb/ft torque. 'Nuff said.
Old 11-20-2003, 11:05 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Yep, always paint everything ('cept maybe clear parts...) Unpainted plastic, even if 'molded in color', will always look awful. It doesn't really matter if you don't really detail the underside, but you don't want to leave anywhere unfinished. Another nice touch is after the body is painted, anywhere the inside of the body is visible (under fenders/wheel arches etc), paint this area with flat black or a flat primer colored grey. Again, this simulates anti-rust undercoating, and it means you don't have to look at unpainted plastic.
Old 11-21-2003, 08:16 AM
360spider's Avatar
Overspray? We are not in 70's anymore! Mazda's bodies are monocoque structures, that are rotated in the spray booth, so they are painted everywhere, even inside the body.
I usually paint every single part in the kit, including body insides.
ItalianHorses.net
Old 11-21-2003, 11:49 AM
600sel's Avatar
600sel 600sel is offline
Nr 1 rule in modeling: PAINT HIDES NOTHING.
Does the chassis plate number have anything to do w/ the car number? Cobra4B GTRA / GTWS / GTS 3 01-13-2008 06:34 PM
How should i go about painting the chassis? HPIracer Car Modeling 7 09-05-2003 08:40 PM
Painting the chassis (I'm going mad...) shieldwulf Car Modeling 19 08-09-2003 12:19 PM
Wtb: 89-93 Fastback, Anyone Willing To Give Up Just The Chassis? musicsurfman 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 06-27-2003 04:44 PM
Does anyone know the Chassis codes? etantshi Engineering/ Technical 14 07-10-2002 02:35 AM
