Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 11-17-2003, 10:54 PM
bdarnton bdarnton is offline
Unhappy Rough Idle in 2002 Explorer
We recently had our vehicle in to get the water pump pully replaced (it was squealing) and since then the car has been idling a little rough. Is it possible that they tightened the belt too much or is it something else entirely?? I know next to nothing about cars and don't want to get raked over the coals when I take it in to the shop. (i.e. Gee your entire engine is bad, that will be $5000). I want to at least sort of sound like I know what I'm talking about.
Old 11-21-2003, 10:58 AM
czechyour6 czechyour6 is offline
The air flow meter went bad on ours at only 16,000 miles but it did not appear to make it run rough, just crappy gas mileage, but if they don't work even a little bit, then that may be the problem. A code should pop up if that is what it is, I thought I was the only one that always had something else happen when I took a vehicle in for repair
Old 11-22-2003, 01:48 PM
Lunarpancake Lunarpancake is offline
Re: Rough Idle in 2002 Explorer
by iding rough what do you meen?......i find that if i dont let the vehicle warm up (2003 explorer...1500 miles).....the engine can idle or back up with almost a revving sound. .......in other words even tho im putting adeqite and even pressure o the gas it feels like im revving the engine.
2002 explorer v8 4wd eb high idle and shifting problem BAKERCONTAINER Explorer | Explorer Sport Trac 0 02-03-2010 01:22 PM
Help with 97 Villager rough idle dscott1838 Villager 12 05-09-2009 09:34 AM
Rough Idle Mayathebee Cougar 1 03-22-2009 08:23 PM
rough idle '98 explorer Spot Explorer | Explorer Sport Trac 0 06-29-2003 01:16 AM
