Old 11-17-2003, 06:24 PM
Xplosive_Eclipse Xplosive_Eclipse is offline
Body Kit & Front Suspension...
Ok, my blitz kit is still on the way, but i'm looking very closly at the front end of my car, and it already looks rather low with the stock front bumper, i need an inexpiensive way i could raise it up alittle bit, just like with some shocks or struts, nothing like electrical coils and stuff, I just really wanna get this kit on and i don't wanna mess up my kit because it being so low. The rear end suspension is fine like it is now, just need to work on the front, so any ideas or (inexpiensive ) suggestions would be great Thanks
Old 11-18-2003, 05:07 PM
duckydsp's Avatar
duckydsp duckydsp is offline
Was your car previously lowered?
Body kits are made to fit on your car and not drag on the ground. Usually you wouldn't have to worry unless you live in an area with really crappy roads. Eclipses have a wishbone suspension in the front end and the back end, i am not sure but i think has an independant macpherson strut setup. I wouldn't recommend raising your car because then you will probably have alignment problems. When you raise or lower your car, there is a good chance you will have castor or camber problems(I forgot which one). There would be ways to raise it. I am not sure how but I just wanted to warn you of the problems you may have if you do raise it.
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
Old 11-18-2003, 09:45 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Body Kit & Front Suspension...
its camber, and companies make camber kits to correct it...
