Old 11-17-2003, 06:24 PM
mattbrye mattbrye is offline
Internals or Turbo 1st??
Sup yall, I want to get a turbo eventually in my 99 ls...ive heard many stories of blown heads from turbos. SO should i get internals befor ei get a turbo?? What all falls under the category of internals and whats the price for all of the internals?? How much boost and HP gains do internals give??
Old 11-17-2003, 06:27 PM
hayhursm hayhursm is offline
Send a message via AIM to hayhursm
Re: Internals or Turbo 1st??
It depends on how much boost you want to run.
Old 11-17-2003, 07:04 PM
I will want to run around 7 or 8 psi daily and be able to turn it to around 14-16 on the drag strip..so should i go with internals 1st?? and what falls under the internals categories besides pistons??
Old 11-17-2003, 08:13 PM
f22a6 f22a6 is offline
you will need pistons,rods,and have the bottomend fully balanced you'll probly want to replace your main bearing bolts and head bolts with studs also use a better headgasket like one made out of copper
Old 11-17-2003, 10:16 PM
I am not sure but doesn't the LS run a 9 or something to 1 compression ratio. If that is the case I have heard of people running about 10psi on stock engines with a block guard but 16psi is getting up there so ya I would definately put, rods, pistons, rings, and since you have it apart through a block girdle on there to. I am planning on running 26psi-30psi on the strip with my B16A2 so I had mine sleeved by AEBS, they do great work and I would highly recommend them. Also you should look in to Total Seal piston rings. They have a Max Seal set that I am planning on getting that would be perfect for you. It has a gapless top ring and you get a leakdown of 2% or less which means less blow by and less oil contamination. They really are cool rings and the techs there are easy to talk to if you have any questions. I would stay away from copper gaskets most of people I know who run high boost just put the Honda OEM back in and it holds up great.
Old 11-17-2003, 10:38 PM
Hey what is a block gaurd?? and all the internal stuff you just said kinda confused me, i dont know a whole lot about all that but i am sure i can go to my local shop and they can tell me all about it huh?? But whats a block gaurd?
Old 11-17-2003, 10:46 PM
A Block Guard goes around the sleeves to keep them stable under boost, see Honda's have "free floating" sleeves in which the deck is not closed but it is open. If you go to your shop and they have a head off of a Honda block it will be become more clear. I would send you pictures but they are to big of files.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
