Old 11-17-2003, 06:19 PM
mattbrye mattbrye is offline
What is an ECU??
Hey guys i got a 99 integra LS...its stock now im looking to change that. If i get a new ECU will it do anything good even though my car is stock, and what exactly is an ECU? HOw much are they and what kind of gains would i see with my stock teggy with a new ECU?? Thanks guys
Old 11-17-2003, 06:44 PM
matt56 matt56 is offline
Re: What is an ECU??
an ECU is your cars computer it controls a lot of electric stuff on your engine. but im not sure what gains you'll get. oh and yeah you should get a little more horsepower if you up grade your ecu. not 100% sure though
Old 11-20-2003, 06:25 PM
b's b's is offline
if i was you (my opinion) wouldn't start out with changing the ecu. it runs around 500-2000 depending on what you want and brand. if the car is stock you're not going to gain that much horse power, i don't think. you really don't need to change the ecu unless you have; turbo, bigger injectors, bigger cam(s), or done alot of upgrade internal or external to your engine. most upgrades don't require changing the ecu. but it's up to you
the ecu, engine control unit i think that's what it stand for. it reads off all of your sensor on your engine, for example like your oxygen sensor and your coolant sensor to tell when to give it gas and let off gas when you frist start the car to warm it up. it read your injector to tell which injector to pulse fuel in the the cylinder. i think you get the point. but yeah that all the ecu does. it read and tells what needs to be done to get the job done right. (keeps the engine running)
Old 11-20-2003, 07:39 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: Re: What is an ECU??
If you don't even know what an ecu is, I would recommend you don't buy an adjustable one and screw up your engine.
Old 11-22-2003, 05:56 PM
chechin chechin is offline
Send a message via Yahoo to chechin
ECU = Electronic Control Unit
bye.
