Old 11-17-2003, 05:30 PM
DerJager DerJager is offline
excessive noise
I own a 1999 Olds Intrigue GLS. The road noise in the rear seat of the car is almost unbearable. Is this a common problem, if so is there a remedy?
Old 11-19-2003, 09:47 AM
burijon's Avatar
burijon burijon is offline
Tires are usually the culprit in road noise. I recently bought a set of Falken ZIEX 512. http://www.falkentire.com/html/produ...12/ziex512.htm
Consumer reports rated this as the number one tire in a comparison recently for all season passenger car tires. These are H rated tires which will ride firmer than the stock Goodyears but are amazingly quiet. I was worried at first because of the higher speed rating than the T and S ratings usually on Intrigues but am amazed every time I drive the car. No more wallowing ride and the tires are quiet indeed. 60k wear warranty is kudos as well.
Undercoating the wheel wells over what the factory/dealer has done may help. Cans of rubberized undercoating should be available at most auto parts stores. Undercoating the whole car helps out a bunch with deadening the noise.
Sound dampening helps alot. Dynamat is probably the most common name that comes to mind. http://www.dynamat.com/spec_dynamat_original.htm
There is also "Brown Bread" which is a roofing sealer but has similar properties to Dynamat but is cheaper and available at Home Depot or Lowes hardware stores.
http://www.dynamat.com/sound_dbate_X...comparison.htm
Another thing that comes to mind is perhaps the rear door seals or your trunk seal are not doing their jobs.
Hope this helps!
Old 01-28-2005, 11:00 PM
Renegade2k Renegade2k is offline
Send a message via AIM to Renegade2k Send a message via MSN to Renegade2k Send a message via Yahoo to Renegade2k
Your tires may be cupped from a bad alignment. make sure you have your alignment checked when you get new tires
Old 01-29-2005, 12:20 AM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
Re: excessive noise
Don't forget the possibility of a rear wheel bearing! It can be very similar to tire noise.
Old 02-03-2005, 08:19 PM
illinoiswronski illinoiswronski is offline
Re: excessive noise
Before winter I had the stock tires replaces with Michelin MVX4+ tires from Costco. I was amazed how much quiter these were.
Front end noise Bob Moore Dakota 5 07-25-2009 04:40 PM
limousime 1.9 TDI 1999 ventilator belt noise kmiki '97+ 0 04-20-2009 02:40 AM
90 Caprice lower engine noise? jomo3423 Caprice 4 04-18-2009 06:23 PM
1999 Ford Expedition (E.B. Edit.) -Loud Grinding / Crunching noise in first gear UnluckyDucky Expedition 0 03-13-2009 06:03 PM
2005 G5 - V6 Clicking Noise in engine donnap1957 G6 9 02-26-2009 07:44 PM
