Old 11-17-2003, 02:58 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
engine specs for dyno2000 program
a friend of mine sent me the Dyno2000 program, which is a program that you enter the specs on your engine and you can modify things such as cam profiles, bore, stroke, etc and it will tell you what power changes you can expect. i'm trying it out just to see what its like, but i'm needing some specs. if you can help me out that would be great.
The specs i need are for the d16a6:
bore and stroke (inches)
intake and exhaust valve sizes (inches)
induction flow (cfm) @ something (inHg)
manifold type (single-plane, dual-plane, tunnel-ram, individual runner (I.R.), tuned point injection, sequential-fire injection)
type of lifter (hydrolic flat-tappet, solid flat-tappet, roller solid or hydrolic)
intake and exhaust lift@valve (inches)
there is also this section at the bottom that says:
IVO (BTDC), EVO (BBDC), IVC (ABDC), EVC (ATDC)
when Stock Street/Economy camshaft is selected, the values are:
IVO (BTDC): 12.0, EVO (BBDC): 66.0, IVC (ABDC): 62.0, EVC (ATDC): 10.0
any idea what that is and if its correct?
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 11-20-2003, 01:23 PM
Jay eS Iye's Avatar
Re: engine specs for dyno2000 program
wow, lots of views but not posts...
well i don't need the bore, stroke, or valve sizes, i searched and found them, but i still need the rest. any help at all???
Old 11-20-2003, 04:40 PM
chopstick1981 chopstick1981 is offline
I use the dyno2000 program, but I use it for my v8 build, not the honda, i doubt this program would help at all with a honda motor. There's not a whole lot of things that can be done with a honda motor short of forced induction, this program is mainly for choosing between the thousands of heads and cams out there for v8s and such. try asking around the forum, chances are anything you wanna do has already been done by someone on this forum
Old 11-20-2003, 05:06 PM
Jay eS Iye's Avatar
i'm actually just wanting to do it just to do it, my buddy sent me the program so i'm interested to see how well it works
Old 11-20-2003, 05:15 PM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
-need a flow bench, flow @ x intake manifold vacuum
-sequential, but for it to be accurate it should need to know what cross section, length, and plenum volume
-solid flat tappet
-Advertise Duration: Int=222 / Exh=224
-Duration @ .050: Int=194 / Exh=196
-Lobe Separation: 110
-Gross lift: 333/362
My guess is that the program will be WAY off, it does not ask for some very important variables.
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 11-20-2003, 05:31 PM
Jay eS Iye's Avatar
well i've already entered alot of info, that was just what i couldn't find. we'll see once i get everything in tho. as for hte flow bench, what is that? is there a stock number that i could use?
Old 11-20-2003, 05:49 PM
well the flow bench is the machine that measures airflow through cylinder heads... Im guessing that might be a little difficult to find for honda heads. but you might want to try and find some *.dyn files on the net, which are dyno2000 files other people have created, i have ran across a couple of v6 hondas and eclipse files myself. then you could use all the airflow and cam specs from it. I've never tried this program for my honda, but i've tested it against some v8 dynos i've found and it has always come within about 20 hp/tq of the value, so it seems to me to be pretty acurate.
Old 11-21-2003, 12:55 AM
91civicDXdude's Avatar
my experience with the program is that you can use it like a G-Tech.. for comparison only. In order to get the stock numbers from a honda (B18A1 = 130hp, B16A = 160hp, etc.) i had to use the "single plane manifold" and run with "hp manifolds & mufflers". It also puts the torque figures very high, but usually the peak numbers @ rpm is usually pretty accurate (the correct peak horsepower rpm)
Old 11-21-2003, 07:38 AM
Jay eS Iye's Avatar
alright, i'll play with the manifolds then. but i still need:
induction flow (cfm @ inHg)
intake lift@valve (inches or mm)
exhaust lift@valve (inches or mm)
and if anyone has them, the IVO, EVO, IVC, and EVC and if they know what the hell than means.
Old 11-21-2003, 07:42 AM
mightytexn's Avatar
mightytexn mightytexn is offline
Send a message via AIM to mightytexn
Im guessing IVO=intake valve open, EVO=exhaust valve open, IVC=intake valve closed, and EVC=Exhaust vavle closed, but don't know what they want for the numbers there
I'm Jordan
My car is the ugliest one on this board
engine specs for GT-WC cars Panoz26 GTRA / GTWS / GTS 0 06-23-2009 05:41 PM
wat are the engine specs for a 2000 z24 cavalier? no_import2007 Cavalier 7 03-17-2007 01:43 AM
engine specs for 94' prankstar C/K 5 07-13-2005 10:26 AM
Engine specs for gen3 integras and piston help 90gs Integra 5 06-12-2003 03:15 PM
