Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 11-17-2003, 10:38 AM
kimchi kimchi is offline
idling level low
When I'm stopped at a light or in traffic, Idle goes low and engine just stops. As long as car is in motion, engine seems to be running fine. When the car is in park, rpm dips a little but does not shut off. Only when it's in drive and stopped, it shuts off. Is this a timing belt problem, or something bigger? The cae has over 80,000 miles on it.
Please help.
Old 12-14-2003, 04:16 AM
GBean009 GBean009 is offline
Re: idling level low
When was the last time you changed/cleaned your air filter? I had the same prob, hten I replaced the filter, and no more problem.
Old 01-14-2004, 09:12 PM
Protegeboi Protegeboi is offline
it could be ur charging system...have some1 check ur battery,alternator,belts... do you have a system is ur car that might be the problem too, ur battery can't handle ur audio system.
