Old 11-16-2003, 11:44 PM
Racincc85's Avatar
Racincc85 Racincc85 is offline
Send a message via AIM to Racincc85
chevy 305 heads
i was thinking of getting a 1977 trans am with the olds 403 motor and restoring it. I wanted to up the compression ratio to get more power, and was wondering if the heads off of a 305 motor will fit the 403 block. if anyone knows it would be a great help. thanks!!
Old 11-17-2003, 07:40 PM
b's b's is offline
Re: chevy 305 heads
i have put a 305 heads on a 400 sb. there was some differences in them. but to me the easiest way to up the compression ratio is to just get a higher compression piston.
Old 11-17-2003, 09:09 PM
texan's Avatar
texan texan is offline
Writer Mod
Re: chevy 305 heads
Or an aftermarket head with small closed chambers (provided the stock pistons won't smack into them or the valves). MUCH more powerful than OEM 305 heads.
'03 Corvette Z06
'99 Prelude SH
Old 11-28-2003, 06:48 AM
kbro kbro is offline
Re: chevy 305 heads
I think a 403 is a big block and a 305 is a small block
so no it won`t work. the easiest way is to get your 403 heads shaved at a machine shop or even better
buy some aftermarket heads.good luck
1986 camaro 305 mods MattLast24 Engine and Transmission 2 07-01-2010 01:56 PM
305 heads vs. 350 heads bobboinge Blazer 4 02-11-2005 02:32 PM
77 T/A Olds 403 heads 305 heads Pvt_Murphy Engineering/ Technical 2 01-11-2005 02:35 PM
305 heads on a 350 good or bad idea RockReadyYJ General Discussion 5 12-13-2003 03:40 AM
Chevy 305 Engine hp/tq? / axel ratios Drewvinille Silverado 1 03-24-2003 07:48 PM
