Old 11-16-2003, 06:07 PM
armyman06 armyman06 is offline
HYPERTECH questions
I was just looking at hypertech programmers, and got sorta confused......do you have to run Premium Fuel if you use a hypertech, or is it just recommended if you want optimum performace. I am really not interested in running premium fuel. I just would like to mess with my top speed limiter and transmission shift points and firmness.
Old 11-16-2003, 06:34 PM
TXAGG05 TXAGG05 is offline
I had a Hypertech Power Programmer for a '99 Tahoe and I'm pretty sure its still the same deal. You only have to use premium fuel if you use the power tuning option on the programmer, it advances your timing for higher octane fuels. The other options were changing tire size from stock, changing transmission shift points/firmness, change for a different thermostat, change for a different rear-end ratio, and change of top speed rating up to 128MPH. You could change all these options independently. My programmer was a Power Programmer III, some may have different options.
jeb
Old 11-16-2003, 07:19 PM
Musial-6's Avatar
Musial-6 Musial-6 is offline
Re: HYPERTECH questions
Do not buy hypertech. They are junk. If you are going to go with a programmer, go with Superchips.
My buddy that deals in both of them says that about 1 out of 2 come back with something wrong.
Old 11-16-2003, 09:58 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Whats so great about Superchips?
Old 11-16-2003, 10:22 PM
Musial-6's Avatar
The fact that they don't break as often is the main thing. Hypertechs are always being brought back with some malfunction, Superchips are not. If autozone sells it, it can't be that good....lol.
I also like the fact that they are VIN locked, but can reset your truck to unlock the programmer. That means you can use it on many trucks to come. I don't know if Hypertechs are VIN locked.
Old 11-17-2003, 10:01 AM
jeverett's Avatar
You can use a Hypertech on one truck, and only on the year model specified on the box. Like mine for instance, I can use it only on a 99. And when it's installed on my truck, it cant be installed on another unless mine it re-set back to stock.
Old 11-17-2003, 10:52 AM
Musial-6's Avatar
Superchips become vin locked when you use them on your truck, so they can't be stolen, but if you sell the truck, you can reset it to stock which will unlock the superchips and it can be used on the next truck you buy. No matter the year, as long as it's the same make.
Old 11-17-2003, 04:21 PM
zed332l zed332l is offline
Smile predatorIII vs hypertech
I have a 2000 silverado with the 5.3 engine. I was considering the Hypertech very seriously, however I went with the Predator III for many reasons. 1. As someone previously stated you can only use the hypertech on 1 truck. You can used the PIII on other truck(s) 'PROVIDED' you unload the the power program buy insatalling the stock program saved in the predator....basically cleaning out the unit(obtw) it is multi year application and engines mine covers from 99-2003 thru all engines except diesel). 2. 30 day return policy. 3. The biggest plus was that it is also a diagnostic tool/ will read and clear codes. I am an ex mechanic, for an extra $75.00 I paid $425.00 at my door it was well worth the money. (only complain shipping was a little slow about 8 days) all I can say about the programer is...... WOW...... MPG went from 9-10 to 14 -16 on 92/93 octane and the power /torgue curve is totally assume.At 90 mph the tach went from approx 1500 to approx 2100 in overdrive. Push the tow/haul botton in at a toll both and hang on to your a$$.... And it does now go approx. 130 mph vice the 92mph set at the factory..
I tried this out on an unused runway @ a military base.
Old 11-17-2003, 10:29 PM
jeverett's Avatar
Does that Predator have options to change for aftermarket tire size and have an option for shift points and firmness?
Old 11-18-2003, 02:48 PM
blucreek blucreek is offline
How about Diablo?
Anyone runnin Diablo preditor programmer?
Another car stereo question Speculant Car Audio 11 08-18-2010 06:37 PM
2000 E150 question ZZT Econoline 1 11-25-2009 11:15 AM
exhaust question 89corollajoke Corolla/Matrix/Voltz 2 07-08-2009 11:22 AM
Hypertech Question... LT-Z71drvr C/K 0 04-05-2005 10:01 PM
2002 tahoe 5.3L z71 hypertech Question MentalState Tahoe 0 08-17-2004 01:53 AM
