Go Back   Automotive Forums Car Chat > Renault > Mégane
Old 11-16-2003, 08:04 AM
philippos philippos is offline
Question immobiliser
help
i have bought a megane from the uk, and i live in greece.
during the summer the immobiliser was set off and the car will not start.
it will cost 1500 euros to be taken in the nearest dealer, an amount that i can not afford. is there any way to disable the immobilizer with the key or without it?
Please help me.
it has been in the drive for 1 month now.
Old 01-09-2004, 04:25 AM
tikki tikki is offline
Re: immobiliser
You will have to get a key code from the manufacturer.
Old 12-07-2004, 07:09 AM
Tuatara Tuatara is offline
There is a good guide at:
http://www.retro-renault.com/forum/viewtopic.php?t=806
Hope it helps you too. It worked for me. I had to get code for my car from authorised Renault service.
Old 05-19-2005, 05:44 PM
Angel-eyez Angel-eyez is offline
I have an email addy for this guy. He can give you the code for your renault so long as you can provide him for the VIN number from the inside of the door.He takes a tenner for doing it but its well worth the pennies.
You then use the code to switch off the immobiliser using the central locking button inside the car and the flashing immobiliser light on the dash. Amazingly it works but when you switch off the car after say 20mins it goes back on so you have to do this often
hes pretty clear with instructions and goes thru the procedure
[email protected]
Old 11-11-2005, 09:09 AM
xplode14 xplode14 is offline
Send a message via MSN to xplode14
Re: immobiliser
[email protected]
Hello, I have a megane 1.4 1997 and i have the same problem, and i use the same solution, it really Works.
Alex from Portugal
Old 02-22-2006, 07:15 AM
bluehawk06 bluehawk06 is offline
Re: immobiliser
Dennis @ Blue Hawk Electronics
We are able to bypass the immobaliser in most Renault E.C.U's which will do away with the immobaliser altogether please contact for enquiries : 07773289170 / 01159539077 / 07966684240
